Hard Wiring a Radar Detector
I need a fused source that's hot when ign on. I was looking around the fuse box but saw no extra terminals. Do I have to tap an existing wire? If so, which do you suggest?
You could tap into the acc wire on the radio. It is already fused, but you could put your own in-line fuse if you like.
Or you could set up a relay if you are afraid of taking too much power from the radio (which a radar detector won't).
I forgot to mention, the accessory wire for the radio is gray. If you have an aftermarket radio, you could use the remote out wire (blue/white), or tap into the red accessory wire.
Originally Posted by JohnnyStorm
I just chopped the wires, grounded the negitive and put the positive wire in with the fuse. I comes on when I turn on car and cuts off just the same! Keep your cig lighter for your cell phone charger.
stab teh left side
stab the left side on the fuse block,,, the right side is the hot side,,, left side is the fused side...
I wrote a DIY on bringing a relay / 30A (300W) worth of power into the cabin - you only need a very small amount for teh detector...
https://www.scionlife.com/forums/vie...0a+power+cheap
don't cut any wires!!!
baby jesus cries every time someone cuts a stock wire!!!11
- Saylor
- Saylor
