headlight bulb change
can someone give me some instructions on changing headlight and fog lamp bulbs....
i got some new ones i want to put in......thanks.........
Transfer the connector grease from your OEM bulbs to the new ones..
Can't help you on the switch itself since I drive an echo. If it's similar though, you turn to bulb housing and pull it out. Make sure you don't touch the glass of the bulb at all though. It'll create a hot spot and your bulb won't last as long. If you do touch it, wipe it down asap.
