Help on HID
Old 09-30-2006 | 01:19 AM
JCool's Avatar
Default Help on HID
Need help so bad...II got the oznium kit today, hook it up and try so many combinations, and finally got it to work..but i don't know why the blue high beam signal on the dash is on all the time..eventhough i m not on high beam, but when I turn on high beam, the light keep flashing...Anyone? (and the way that I hook it up is the only one that both hid and halogen are working?
Old 09-30-2006 | 05:02 AM
365Motorwerks's Avatar
First off give Phil a call they are very helpfull!
Here is how the connections are on the H4 bulb, make sure the HID is on the low and the halogen is on the high, don't know much about the kit you got but it might also be a polarity issue, start with just hooking up the xenon bulb as the directions say to the low pins and see what happpens...
Old 09-30-2006 | 05:09 AM
JCool's Avatar
thank you very much i will give a try tomorrow..
Old 09-30-2006 | 06:54 AM
Welcome and good luck...
Old 10-01-2006 | 10:53 PM
How'd it go you figure out what was happening?
Old 10-02-2006 | 06:35 AM
LEDmod's Avatar
How could you get the bi-xenon to work with xB??
When you flash the high beam it turns off the low beam....
Old 10-02-2006 | 06:40 AM
Kit he has isn't BiXenon but the BiXenon kits use a control box so when the highs are selected the power to the bulb stays on while the servo repositions the bulb for your high beam..very slick!
Old 10-02-2006 | 06:50 AM
LEDmod's Avatar
Cool... I'm planning on getting the bi-xenon kit with sliding fuction...
But I'm just worry that when I put them in high beam low beam turns off...
Since you don't want to turn on/off repeatdly on the ballast...
Old 10-02-2006 | 07:01 AM
Yep thats the way to go PM me when you are ready...
The kit JCool got is from Oznium and uses a halogen bulb for the high beams as most Hi/Lo kits do the Xenon shuts down while you are on the highs for that type..halogen is not really a high beam substitute it's really just there to do a quick flash or can be wired in as a city light to your parking light circuit.
Old 10-02-2006 | 07:06 AM
JCool's Avatar
i don't have time to check out yet....i will try to check that out with the meter...
Old 03-20-2007 | 05:06 AM
tintin's Avatar
Default Same problem
to make it work, I had to instead plug it in green with black, black with green, and unplug the yellow. Took me a long time to figure that out!
Using this method, the High-beam symbol will not lit on the dash, but you will totaly lost the high-beam funtion, if you turn on the high-beam switch, the HID will go out with out flicking but the High-beam is still not working. only the High-beam symbol will lit on the dash.
sciontc008
Scion tC 1G Aero & Exterior
01-20-2016 06:10 PM
hondajt
12-14-2015 01:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
10-15-2015 04:09 AM
alias55
Scion tC 1G ICE & Interior
09-22-2015 08:50 PM
Renuco612
09-16-2015 10:01 AM
Quick Reply: Help on HID
