Hidden LED grab handle's...
#42
Re: Hidden led's in grip
Originally Posted by WhiteBlazer01
Originally Posted by tdub57
The LED strip lights on autolumination.com will accomplish the same thing with a lot less work. already pre-wired and encased in plastic. See my post
http://autolumination.com/fixtures.htm
#43
http://www.bocaflasher.com/led-catal...gin=fail#LogIn
These look cool too... but I couldn't find any price info...
They even have a color changing one
Also, this looks like it would work too... how long is too long?
http://cgi.ebay.com/1PCS-x-7-Thin-LE...QQcmdZViewItem
#44
Hidden LED;s in the grab handles
Yes those are the ones from autolumination. You can buy them with or without the blinker box. All you have to do is trim down the plastic housing a little and they fit inside the handle once you trim the ribs on the underside. I didn't take pictures while I was installing them, but if you follow the instructions from the original post you'll be fine. They give off alot of light. Also autolumination has some other LED light fixtures that with a little imagination can go a long way.
SL is the best thing that's happened to my BOX
#45
#46
Where did you guys run the wires to/through? under the headliner somehow? or down the pillar between the doors and under the seat to the center console? Also, if i've NEVER, ever soldered anything in my life....how risky is it to try it on an itty-bitty resistor?
#47
not risky at all. Its easy as pie for stuff like this. Its almost like using superglue :D
I ran my wires just along the headliner, down the pillar, up to the front under the plastic trim on the floor, to the switch in the center of the dash.
