High output alternator for battery drain
I will have to agree that I have never heard anything bad about Kinetik batteries. I know plenty of people that run them as a car battery as well with no probs, I need to swap my Optima out for Kinetik actually. I used Optima a few years ago when Kinetik was just starting and I was not too sure about them, And now that I have gone threw prob like 5 replacement Optima batteries I wish I had gone with Kinetik when I had the chance to get them at the sound shop I was working at back then. As a matter of a fact I have another dead yellow top in one of my xBs right now, cause I did not drive it for a week.
Winter, thank you, you seem to be one of the few people who understand this problem. I'll try and reiterate it though.
I am not looking for a battery that can handle high current draw. My system would only be using about 1200W Max, and this would be with everything full volume, both displays on, etc.
My issue is that, in a 24 hour period, the car is only running for about 30-45 minutes, which is the only time the battery is charging. For the other 23 hours, there is a Mac mini carputer sitting in sleep mode, but still on, drawing a smaller but unknown ammount of current. The power draw over 24 hours is greater than the charge capacity for the 30-45 minutes, resulting in a dead battery over two weeks or so unless an external charger is used. Here are the possible solutions, pro's and cons:
1) Bigger alternator
A larger capacity alternator will increase the charge capacity of the system, hopefully recharging it enough during that 30-45 minutes to sustain the other 23 hours of battery drain.
Pros: Self sustaining, easy to install
Cons: Expensive, if charge is still less than draw over time will not work
2) Bigger battery
A larger battery will allow for the car to hold more charge, running for longer before being depleted.
Pros: Cheaper, easy to install
Cons: Only delays the battery dying, not fixing it. Will still need to periodically be externally charged
3) Second battery w/ relay to de-couple when car is off
Uses a second battery that will charge from the alternator when the car is on, then disconnect from the main battery when the car is off and only power the computer.
Pros: Will not drain the main battery, car will always be able to start
Cons: Secondary battery will need external charging, will shut down computer when drained.
The question about amp hours is an easy one to answer. It's a measure of battery capacity, saying that for one hour, the battery can continuously give out the rated number of amps. At the end of that hour, it will be fully discharged. The bigger the number, the more storage capacity a battery has. If the Optima and Kinetik both have a 60 A-h rating, they have the same capacity. Drawing 60 Amps continuous will kill both of them in one hour. If Kinetik has a 1500 A continuous rating, it's pretty useless unless you're really drawing that much power, which for speakers would be around 18,000 Watts. With a 60 A-h rating, drawing 1500 amps would kill the battery in 2.4 minutes. Max continuous output is affected by internal resistance, which causes heat buildup.
BTW, Kinetik isn't a "dry" cell. It's a sealed lead acid battery (SLAB) that happens to use a fiberglass separator to retain the acid electrolyte between lead cathode and anodes. This is the same type of battery used for flight applications because of thermal and physical shock resistance and multi-axis orientation capability. A true dry cell uses an electrolytic film, is usually basic (high pH) and not a suspended acid. I do have to call BS on Kinetik when they go into the load balancing thing. Kinetik is in the business of selling batteries, it would only be natural for them to say "for best performance, only use Kinetik in multi-battery setups". Current reflow is really a function of the different battery capacities and interconnect wiring resistance and is brand independant.
For high current draw, SPL applications, I'd go with Kinetik, Batt-cap or another SLAB battery. However, I need high capacity, low current draw so I'll be going with the cheapest battery with the most A-h.
2) Bigger battery
Originally Posted by Skitzo_xa
Originally Posted by Winter
also, it's not wise to use any of the Kinetik batteries in place of the stock battery. if you are going to replace the stock battery, replace it with a gel cell like Optima. Kinetik's batteries are dry cell batteries and will discharge their energy VERY quickly. so if you have anything being powered while the vehicle is turned off, you WILL come to a dead battery in a matter of hours where as the gel cell will keep a similar charge to that of the factory wet cell.
Kinetik HC1400
Ah 60
AMPS 1500 Continious!!!
Optima Redtop
Ah 60
CCA 720
CA 910
STRAIGHT FROM KINETIK
"-Mixing Different Battery Technologies
Kinetik Power Cells are compatible with most standard 12 volt charging systems and battery technologies. We do however advise using Kinetik Power Cells exclusively throughout the vehicle for maximum voltage, performance and longevity of aftermarket electronics as well as the Power cells. This will minimize self discharging of the power storage devices in the vehicle while not in use also. Kinetik Power Cells have a very low self discharge rate much lower than that of a standard ‘wet cell’ car battery. When different types of power storage devices (batteries or Power Cells) are used in parallel in an electrical system, current will have a tendency to flow between storage devices unnecessarily resulting in heat build up and loss of power where it is needed most. When Kinetik Power Cells are used throughout the install, current will flow directly from the Power Cells to the load in a balanced manner minimizing ‘fighting’ between unlike storage devices."
When weere Optima batteries used in a SPL car to make 180.5db?
Optima is $160-$180 depending where u go, a HC1400 is $200-350
I think i will always pay the extra money for a battery that will last me way longer.
I sell both Optima and Kinetik and I will tell someone to buy a Kinetik everytime. I know from exerience and all my customers and friends know what i what, If your gonna dick around and buy 50 thousand batterys in your lifetime then get the Optima, if you want a battery that will out live you then get a Kinetik.
Using a Optima is like you wearing diapers, using a Kinetik is like never making in your pants again!
your vehicle will only stay as reliable as you let it be. fail one time and it may be something that will put you in a dangerous situation...
use a Gel cell for the main and a dry cell for auxiliary, it doesn't get any better than that.
Vettereddie - If you use an upgrade alternator from Iraggi, you'll still have toyota's rep on that sucker. i don't know what it is that he does, but his alternators are rock solid. i wouldn't touch alot of the aftermarket ones due to possible repair issues and continuous failures. getting a secondary battery is a good idea, but like you said, you will still continue to have the same problem after a while.
what you need to do is this. tally up the max draw of all the continuous draw items such as your displays, gaming systems and whatnot. add the wattage up. and then when it comes to your sound system, take the total true RMS power of everything and subtract roughly 40% off of that for an average ACTUAL power usage. then add the two together and you'll have the continuous wattage draw. take that result and divide that by 13.8 *13.8volt* which will give you your average total amp draw. from there, you can accommodate the proper alternator over stock so you don't go too over board, you can also help match what auxiliary batteries you'd like to use for the setup aswell.
Yeah, I thought of doing all the calculations, but think I'm instead going to try and get a hall effect sensor from work and hook it to a data logger. When the car is off, the current draw should be consistant, and when it's on, it's always the same stuff, Mac Mini, 7" Touchscreen, stereo at 15 (out of 30 I think), both amps. I should be able to get a decent average after 6-10 minutes. For now I think I'll just power the PC off of a second battery, coupled via relay so when the car is off it's not connected to the main one under the hood. I'll plug in the secondary once a week to keep it charged.
your main concern should be your "off" time current draw. that's the bad zone and don't want that happening when you've got your self parked for the night. you'd be starting your morning with alot of frustration
I 3rd nodsetse and speedshop's suggestion.
2nd small dedicated battery for computer memory, isolated from primary when ignition off and charged when ignition on. Its really the best choice if you want to be able to start the car reliably.
i'm not going to argue over and over. a Kinetik HC1400 would work forever and a day w/o problem. but i aint going to BS about what is better because i know from experience what is what and what will work for the lifetime of a vechicle.
umm... if your tryin to figure out what your Current/amp draw is while the car is off and the mini-mac is "sleeping" wouldnt a "amp clamp" or other current measuring device do the trick?
doesnt solve your prob, but puts ya a step closer
Yes, it would, if you see my post above, the "amp clamp" is a Hall Effect sensor. Now I'm just trying to either find a cheap one or be able to borrow one from work.
Nice link, but hella overpriced.
I was reading up on the DC-DC supply I'm using to power the Mac, it looks like I need to do a reflash of the firmware. It's a Carnetix P1900, found here:
http://www.carnetix.com/CNXP1900.htm
They state:
I think #2 is my problem. It still won't solve the problem of needing to recharge the battery periodically, but at least it will keep me from having to jump it from a portable unit. I'm currently using this when it dies:
http://www.blackanddecker.com/Produc...roductID=15581
They state:
Firmware version 2.8 changes the following:
1. Prevents Mac mini from being able to wake from sleep without going into overcurrent.
2. Changed Low Battery threshold from 10.6V to 11.5V.
3. Extended ACPI pulse from1.5 sec to 1.7 sec. (some Intel Mac minis need this).
anywho... try goin to sears? think i saw their tool catalog have some in the low $100s... and if you keep it clean enough and dont destroy the packaging, could always try and return it as a duplicate gift or something... just a thought
Well, I flashed the power supply but I think it's too late for my battery, it will only hold a charge for 2-3 days now and will def. need replacement.
I'm looking to go with an Odyssey PC1400, just need to find the right price. Still looking into the alternator upgrade, that + reflashed DC/DC convertor should = no need to recharge. I'll be doing the big three as well, not sure if it will matter on a low current, high duration application, but I already have the wire and terminals.
Years ago I had a problem keeping a small battery charged that ran some electrical equipment in a van. Similar to your problem.
I found a solar battery charger in the system to keep the small drain of the equipment was a cheap easy fix. They make them to keep batteries charged in motor homes and the like.
You could try one to see if it kept the battery up while it wasn' t running.
It kept my video and audio equipment up and running 24 hrs a day and I could start the van and leave.
Think like a camper
The diode solution is surprisingly easy, and the voltage difference is not that big a deal. I bought something like this at an auto parts store:
http://www.northerntool.com/webapp/w...2955_200342955
Here's the manual:
http://www.northerntool.com/download...als/171213.pdf
$25 or so for the isolator, buy a decent gel-cell battery, get a dc breaker, run the computer off the second battery - when the car is on, both batteries are getting charged, and your cpu is running. When you turn off the car, the diode blocks the current drain on one battery from the other, so your car can start. And yes, they are very different kinds of batteries. I use one at home to keep my ham radio battery charged, if the power goes out I dont hurt my nice power supply.
You're right that the inverter is eating some power, but as you've found, the mac mini is not made for a dc-dc PS. You could possibly add a small UPS that could tell the cpu to shut down. Also, I dont have a mac, but it might have a sleep mode that copies the ram to the hard drive, so a startup puts you back where you were.
Here's the manual:
This problem has been fixed for a while now. Not sure what the exact cause of death of the old battery was, but swapping it with a new Stinger SP1000. I haven't had to charge it or have it die since.
http://www.stingerelectronics.com/pr...=35&ParentID=1
mischadoll
03-09-2015 05:48 AM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
