How do i run RCA cables to the stock deck (tried a search)
Old 10-12-2004 | 04:18 AM
markritch's Avatar
Default How do i run RCA cables to the stock deck (tried a search)
hey just wondering if anyone has run a amp to the stock deck...im sure someone has. How do i do it with no Pre amp outlets, is there a simple converter or something i can buy, cause i dont want to replace the stock double DIN cause i found no other double DIN i like, thanks guys.....someone just let me know what i need
Old 10-12-2004 | 04:26 AM
BoomBox757's Avatar
DelMarVa
you said you plan th get the kenwood double din so what youd you mean you havn't found one you like? alot of people tap the rear speakers and use some low end filter or something to make sure they get only bass. not how I went,and i don't know much abou it so.......
Old 10-12-2004 | 04:33 AM
oneslowxa's Avatar
wow most units know have at least two sets of outputs... all of the radios we sell have 3 outs, except for some cassete decks...
to amplify without preouts you would need a high/low converter, or an amp that has speaker level inputs.. good luck
Old 10-12-2004 | 04:42 AM
BLKTOYBOX's Avatar
sIcKsCiOnS
Your best beat for this type of set up is get a line level to rca adaptor that will take the line level voltage which is greater then that of rca's and inverts the power. Most good one will have a screw that you can use to help set the correct gain to the amp.
Try car domain heres is a link there are better on the market though. You get what you pay for.
[/url]http://search.cardomain.com/cgi-bin/MsmGo.exe?grab_id=105&EXTRA_ARG=&CFGNAME=MssFind%2Ecfg&host_id=42&page_id=667904&query=line+level+to+rca&hiword=to+level+LEVELS+line+LINES+rca+LINED+LEVER+LINER+LINERS+
Old 10-12-2004 | 05:11 AM
TheScionicMan's Avatar
http://search.ebay.com/scion-RCA_W0QQsojsZ1QQfromZR40
Old 10-12-2004 | 06:03 AM
Zombietime's Avatar
Default Re: How do i run RCA cables to the stock deck (tried a searc
For my basslink, I used a high/low converter and set the gains to about 75%. It seems to be working well and though i'll be upgrading to a standard deck and amp/sub, it's working great for me. I don't have any filters or anything else.
Old 10-18-2004 | 10:49 PM
redneck69's Avatar
Default how is the sound quality
how is sound quality running that inline converter to your amp with the stock head unit? is it noticably different from having an aftermarket hu with rca outs comin strait from it? did you lose sound quality in the rear speakers assuming you spliced into the wires running from the head unit to them?
Old 10-19-2004 | 01:07 AM
i64X's Avatar
Line converters are ghetto. The harness that they sell on eBay just has line level converters on it that are wrapped in shrink wrap. You might as well save yourself some money if you want to use that harness and just buy line level converters. Don't expect clean quality out of line level converters... they're a quick fix. Nothing more.
Old 10-19-2004 | 05:33 AM
redneck69's Avatar
Default line level converters
wait that was sort of confusing.. if i buy a line level converter, one that is basically blockin the highs, and converting the signal down to whatever level rca's run on its going to sound like ___.
check this out
http://cgi.ebay.com/ws/eBayISAPI.dll...725675666&rd=1
ur sayin that the sound quality usin this is definitly not worth it? i would really like to put my subs in the xb, but dont have the money for a new head unit at the moment..
Old 10-19-2004 | 06:37 AM
Zombietime's Avatar
Default Re: line level converters
check this out
You can go to WalMart and get a scosche high/low converter which you can use to hook up your amp. You just tap into the rear speaker pos and neg wires on the wiring harness and then run your rca plugs into the converter. It gets the job done and wont sound bad at all. That one you posted in the ebay link will work just fine too.
Old 10-19-2004 | 09:41 AM
redneck69's Avatar
Default inlinfe converter
ahhh ha! finally the answer i was looking for: it wont sound bad at all. thats what i was looking for. i didnt want to go through the work of movin my amp and subs from my mustang to the xb while keeping the stock head unit in the xb UNLESS it was going to be worth the work... thanks
wiltonhall
01-28-2015 04:46 PM
darkshadowofxdeath
12-03-2014 07:59 PM
BLKTOYBOX
10
03-02-2004 09:36 PM
TJ
27
02-08-2004 01:20 AM
Docofmind
10-25-2003 05:33 AM
