how do u drill out a rivet
hi, i was trying to put in new speakers in my xb in the front doors and theres stupid rivets. how do u drill them out. is there an alternative that i could do thanks
the only alternative is to cut the speaker from the mount....this will trash your stock speakers but you'll be able to use the brackets to fit your new speakers...
to drill them out, get a bit the size of the small indent in the middle of the rivet, and just go straight through it.......it should just fall apart when you drill all the way through.......after removing the old speaker and bracket, you can easily make a new bracket/spacer out of MDF, a drill, and a jigsaw......
you drill out the center of the rivet with a 5mm drill bit then cut the old speaker surround and cut the basket out leaveing the center to mount your speaker to the rears have bolts so you know how to remove those do the same mutalation job to it then you can use those as a base i installed infinity 500si and 600si (deep mount fronts) they have rotateable tweeters and they sound great and are inexpensive
Originally Posted by kacosta
ether way... but someone may want to remove and not know how. i also used the connectors on the basket houseing so the factory connectors could stay.
After you drill out the rivits you can get an adapter to install your new speakers. I got mine from crutchfield.
http://www.crutchfield.com/
surfcitylocal
08-04-2015 06:52 PM
