How to drill out rivets?
Explanations in the following thread:
https://www.scionlife.com/forums/viewtopic.php?t=52635
(BTW, I entered the term "drilling and rivets" into search. Adding the "and" limits the search to what you are looking for.)
Good luck.
Good luck.
Originally Posted by SCI_TC_GUY
buy 1/8" drill bit.
insert bit into drill.
position bit in center of rivet.
pull trigger.
that's a toughy...
pull trigger.
that's a toughy...
one way to remove a rivit is get a small punch punch the center of the rivit out its steel, then get a drill bit larger then the hole of the rivit center and drill it out if the head starts to spin just angle the drill bit so it drills at a angle they make a tool for removing rivits but the kit runs about 40.00
surfcitylocal
08-04-2015 06:52 PM
