HOWTO: Install Cold Cathodes for >$20
Old 11-01-2004, 09:31 AM
  #41
jack_d12's Avatar
but how do i get to the inside of the plastic for the switch ?!?!?! i can take off the part under the ac console and it doesn't seem i can reach into it from there?!?!?! also how would i cut a hole into that piece without drilling equipment?!?!?!
Never mind found out that i had to take out the ac console and remove the cubby hole ... got the plastic off but still don't have drilling equipment ... so i'm just leaving the plastic off and i'll just have the switch there ! it moves around but it doesn't sink into the hole so i guess i'll leave it for now !
jack_d12 is offline
Old 11-01-2004, 01:13 PM
  #42
Max2k's Avatar
Grammar is your friend.
The little plastic punchouts just pop out, use your fingernails. If you don't have a drill or whatever, just hit up your local Loew's and get one of the switches that fits into that hole. They look super clean.
Max2k is offline
Old 11-01-2004, 11:52 PM
  #43
jack_d12's Avatar
no lowe's here in hawaii never heard of em ... i'll check out home depot, radio shack, and walmart later on ... i think the lowe one ur talking about has a red light to it right ?!?!?!? i don't think i want the one that has light that's why ... thanks for hte help !
jack_d12 is offline
Old 11-16-2004, 03:39 AM
  #44
brownbanana's Avatar
Lowe's is in Waikele.., thats if your on oahu though.
brownbanana is offline
Old 11-18-2004, 12:22 AM
  #45
T_Dot's Avatar
Default Re: HOWTO: Install Cold Cathodes for >$20
Originally Posted by Max2k
where did you get that switch from? im looking for the same one, but without the on and off display settings
T_Dot is offline
Old 11-18-2004, 01:18 AM
  #46
DelMarVa
BoomBox757's Avatar
it comes in with the cold cathodes
BoomBox757 is offline
Old 11-18-2004, 04:11 AM
  #47
Max2k's Avatar
If you want it without the little markers just take a normal one and hit it with some rubbing alcohol or whatever. You can cop them separately at www.svc.com
Max2k is offline
randode
44
06-29-2004 04:19 PM
randode
11-20-2003 05:46 PM
Besk_one
11-17-2003 09:28 PM
randode
15
10-31-2003 09:50 PM
BlueBox
9
09-25-2003 04:36 PM
Quick Reply: HOWTO: Install Cold Cathodes for >$20
