Install a 2012 BT/HD base radio in a XB1 (T1819)
So folks i figured it out on my car. for anyone interested in installing a T1819 (2012 base) radio in a 2006.5 minus XB i did it and my aux in is now working. to summarize things you need:
Head unit
3 oem harness that come with it 20+8 adapter, HD antenna, and speaker
BT mic from scion IQ part #
if you have all the above it will work with BT and HD radio now for the 06.5 people with Aux in you need more stuff.
you will need a 2.7k Ohm resistor i bought mine from radio shack in a giant misc pack that cost $15 so i recommend just buying them online. also a small tube of silicone or hot glue
once you have those on the 20pin harness from the car i put the resistor in pin 19 and 18 (red/silver = 19 and 18 is unoccupied) this is a PITA but shove the resistor in port 19 first as far as it will go and then push it all the way through 18 and bend it over the top of the plastic clip so it is held in place.
turn your radio on make sure the aux now works turn it off put a dab of hot glue or silicone on it to hold it in place.
I could add photos but for the most part i think it's pretty straight forward now.
Head unit
DaBlackBox
134
04-10-2022 03:04 PM
clickclickw00t
02-18-2015 09:57 PM
TheRedBox
31
12-02-2003 05:53 PM
