Interior Water Leak Under Console - A/C??
Has anyone experienced water leaks from under the center console near your feet on a 2005 xB? Because mine is leaking what I am assuming is water (no smell and no taste). I was wondering if this is a common problem, or if something ridiculous happened. I read a few of the posts about condensers getting hit with rocks and broken, but none of those mentioned a water leak. Any help would be much appreciated, thanks!!
have you recently had a sound system installed? i.e. amplifiers? is the water on the passenger side also or just the driver side? seeing how the a/c stuff is on the passenger side of the vehicle, and if the water is only on the drivers side, I would start looking for a grommet that might not be in all the way on the firewall.
Yes, I did attempt to taste it, however it had no taste. The water is coming from the passenger side mostly. I called the dealer today and they informed me that it may be a clogged drain pipe that may be causing the problem. I've got to take it in to them anyways because now the A/C seems to only want to have two settings...off, or FULL, which I bet is a resistor somewhere.
DaBlackBox
134
04-10-2022 03:04 PM
xb4lf
04-04-2015 08:15 PM
