Lanzar (vibe-246) and Audiobahn AW1051T hookup?
Ok so heres what I got:
* 2 x 300W RMS at 4 OHMS 2 x 600W MAX at 4 OHMS
* 1 x 1200W MAX at 4 OHMS Bridged 2 x 500W at 2 OHMS RMS
* Electronic Crossover Network
* Bass Boost Circuit
* 2 Ohms Stereo Stable
* Anti-Thump Turn-On
* Illuminated Top Panel
* Soft Turn On/Off
* High & Low Level Inputs
* Power & Protection LED Indicators
* Advanced Protection Circuitry
* Remote Control Bass Booster
* THD: <0.04%
* S/N Ratio: >90dB
* Channel Separation: >65dB
* Freq. Response: 15Hz~35kHz
* Dimensions: 11.06''W x 2.24''H x 13.5''L
I have two of these and they are: (link is http://www.amazon.com/Audiobahn-AW10...897951&sr=8-10)
*Dual 4 Ohm 300 Watts RMS
So my question is, how should I wire these? What I did (which i believe is wrong) is on each of the subs did positive to negative. Then I did negative on sub to negative on the box and positive on the sub to positive on the box. Is this correct?
If not, which one of these diagrams should i follow? (its a list of crutchfield suggestions wirings)
http://www.crutchfield.com/learningc...rs_wiring.html
As how I see it, is that i should just do it straight up. positive on sub to positive on box and negative on sub to negative on box.
* Soft Turn On/Off
* THD: <0.04%
* S/N Ratio: >90dB
My friend used to sell Audiobahn at his shop and can help
Illusions Audio ask for Bill 610-695-9330 he can give you the advice you need open till midnight 7 days a week.
Audiobahn is an expensive equipment I had it in my BMW and you want to make sure you wire it to the specs of the manufacturer.
Just talked to him. Great guy. Helped me figure out just about everything.
He said i should get 2 gauge amp kit, and right now i have 8 gauge. is this necessary?
The way he said for the wiring was to bridge the (+) and (-) together on each sub, then wire the (+) on sub to (+) on box and same for (-). Then i need to twirl the two positive wires coming outa the box and put that in the amp and do the same for the negatives.
bajamike
12-23-2004 01:28 AM
