LED's with a dimmer
Led's do dim. If your going to do your own cup holder thing on an xA, look up under the cup console e-brake thing and there are 2 plugs a blue connector and a white one. pull the blue connector out and with the clip part of the plug facing up you will see 4 pins. The two pins on the left side of the connector are bottom left - Ground, and the upper left - Positive. Those work off of the dash lights and are controlled by the dimmer switch.
Hope that helps.
Hope that helps.
SJMiller
09-12-2015 06:33 PM
