luminics....
#121
Projectors Should take a different size bulb
You might want to double check the size of your projectors. The OEM bulbs are 9006,9005 but I am unsure on which bulbs go on the projectors.
www.LuminicsBulbs.com
#124
I bought a set of yellow's for the stock fogs from Autobacs. Prior to that, I had the BlueBatmobile overlays. Unfortunately, I did not take any comparison pics. I can say confidently that if you want a really 'yellow' look for your fogs, the overlays were much more so than the Luminic bulbs. Up close standing, they look a dirty white...but as you get further away from the car, they become more yellow.
#126
Are the new UV's gonna look something like this?
http://www.cardomain.com/id/qbnlykwhoa05
I love these but there high wattage (80w). I dont want to fry anything.
There so bright though, i mean i have tried like 3 other kinds and nothing matches to the brightness those put out.
#127
i got my UV lights last thurs. they look soooo nice. i would recemend them to everyone. but i only had them for about a day. alitle after midnight friday someone hit my car. the first thing that i got out to check is if the bulbs are still good and they where. but im afaid then they are doing the repairs on everything they might throw them out. so i might need to order some.
#129
they look white. but when i was driving in the rain it made the road look purple. if your worryed like i was that it was all going to look purple it doesnt. they are very bright. there is a huge differnce from stock. im going to get some for my moms xB also.
#130
In the 9006 Uv series we are changing the filament out to get a brighter light out of it.
This is correct the wattage is different on the two series. The 9006 is for your Low Beams 9005 is for your High Beams. Some peopl convert to run the 9005 in there low beams so they will project brighter but I do not recommend that. I would recommend running what is suppose to be in your vehicle. Our bulbs run on OEM or "stock" wattage so if you run our bulbs and the correct series you will have no problems with your wiring.
hey, arent the wattages different for the 9005 and 9006 bulbs than what the maual says???
is it still OK to use these???
last thing i want is a fried wiring or screwed up headlights
THANKS
THANKS
#134
Most of the TC owners that wanted the Ultra Violet and they wanted to wait for the new ones to be released from customs.
#137
Originally Posted by IndigoDreams
what bulbs are our high beams on the tc???? i wanna get some of those yellow ones for my high beams
Tc
LOW BEAM 9006
HIGH BEAM 9005
