Max2k's Lighting (update 5.5.04)
Old 05-05-2004 | 11:31 PM
Max2k's Avatar
Default Max2k's Lighting (update 5.5.04)
Numbers:
2 Under Dash Cathodes
6 Under Seat Cathodes
1 Glovebox Cathode
1 Storage Box Cathode (6")
2 Trunk Access Panel Cathodes
3 Ashtray LEDs
2 Door Speaker Spiral Cathodes
Total: 14 Cathodes, 3 LEDs
Pictures:
If you have questions, fire away!
Old 05-05-2004 | 11:34 PM
foxSCION's Avatar
sIcKsCiOnS
looking good...
Nice and Bright
Old 05-06-2004 | 02:26 AM
got_xA's Avatar
i like the door panel lighting most
PEACE
Old 05-06-2004 | 02:35 AM
ghost's Avatar
N.G.S.O.
Get us some night pics! :D
Andrew
Old 05-06-2004 | 02:55 AM
Max2k's Avatar
Andrew
Old 05-06-2004 | 03:01 AM
mikochu's Avatar
Originally Posted by Max2k
http://www.mikochu.com/junk/rimshot.wav
Old 05-06-2004 | 03:02 AM
toyotaisme's Avatar
Is the color Red or Orange?
Old 05-06-2004 | 03:04 AM
Max2k's Avatar
Red.
Old 05-06-2004 | 04:53 AM
ncscion's Avatar
what www.svc.com part is the spiral speaker lights? is it the wire lighting or premade spiral lighting?
Old 05-06-2004 | 06:07 PM
Al-Truistic's Avatar
Would you be able to still see those compartment lights even with a bunch o crap in them (glovebox and storage under A/C?) I'd love those for my autoBox but what would be the point if you couldn't see it...
Old 05-06-2004 | 07:04 PM
dgHotLava's Avatar
what turns the lights on and off?
are they automatic to the opening and closing of each door, or are they all controled from one master switch.
al, i think the glove box light will be ok if its full of stuff. the ac-compartment is questionable as the light look to be on top but in the back.
still better than nothing...
Old 05-06-2004 | 07:27 PM
randode's Avatar
Wagonistas
the glove box and junk box lights are bad ___! :D
Old 05-07-2004 | 07:17 AM
True that! So, how was this accomplished? Please do share...
Al.Truistic
aB
Old 05-07-2004 | 10:52 AM
chillenn310's Avatar
how'd you do the cathodes in the rear?? they look pretty dope. that was the next mod that I was gonna be working on.
Old 05-07-2004 | 02:32 PM
Reno's Avatar
that looks really good.
Old 05-07-2004 | 08:10 PM
Max2k's Avatar
NCscion: I used the Hypnotiq series cold cathode fan grills (these come with a clear casing, so I'm going to hit them with stained glass paint to make them redder)
Al.Truistic: The glove box lights are fully visible with stuff in the box because it's mounted above the box. The junk box light gets a little blocked, but I only keep sunglasses and CDs in there so it shines through/reflects off them.
DgHotLava: There's one master switch that turns all of them on and off.
Al.Truistic again: The junk box was done this way:
1. Remove dash and junk box/cigarette lighter/ashtray setup.
2. Drill a small hole in the lower right hand corner of the junk box, right next to the brace that keeps it in the dash.
3. Attach a 6" cathode in the top back of the box (I used velcro) and pull the wire through the hole you drilled (you're going to have to open the inverter and unplug the cathode to fit the wire through the hole).
4. (This is where we start putting everything back together) Pull the cathode power wire through the hole in the mounting for the box/lighter/ashtray and plug the cigarette lighter back in.
5. Mount the inverter behind the dash and wire it to your power and ground (it helps to pull off the glovebox when doing this).
6. Wait until nightfall.
7. Find sunglasses, put them on.
8. Turn on your lights and marvel at your technical prowess
This was far and away the most difficult and frustrating light i've done yet, and I reccomend you get comfortable with wiring and lighting before you do it.
The cathodes in back were pretty easy. All the body panels snap off with minimal effort, so all you have to do is pull up the door sills and pull power back. The light is mounted to the sheetmetal on the side of the car.
If you're going to do red lights, i reccomend you pick up a can of Krylon Stained Glass Paint and paint them before you mount them. It will make them a little dimmer but a lot redder. Also, use stranded wire throughout your setup, it will make your life much easier.
AdPock
02-23-2015 07:15 PM
Cadillac15
01-29-2015 08:34 AM
snappe2
01-27-2015 06:29 PM
erroldc
12-18-2014 05:12 AM
Risen_Son_Racing
03-14-2008 10:59 PM
