My ACC Fuse Keeps Blowing....Help
Old 08-05-2008 | 12:36 PM
BOXITUP's Avatar
Default My ACC Fuse Keeps Blowing....Help
Hey Guys, I was driving yesterday and hit a small bump -- all of a sudden my radio turns off. I check the ACC fuse and it's blown. I replaced the fuse and turn the car back on and it blows again. This happened 3 more times. So I took out the radio and tried it again -- same thing. Each time, the fuse blows once I turn the ignition.
I wonder if that bump caused something to become loose -- the problem is that I'm not quite sure where to look first.
Any suggestions? Thanks!
Old 08-05-2008 | 01:51 PM
Improbcat's Avatar
Have you added any aftermarket stuff to that circuit Radio/speakers/amp/lighting/etc? If so I'd double check all the wiring for that first, you may have a power wire shorting to ground.
If the car is stock the search is going to be much more complicated.
alexdrummerr30
09-08-2018 01:18 PM
wayneside
Regional - Southeast
09-23-2015 11:42 AM
DannyBoy65
09-21-2015 07:23 PM
spharr62
09-20-2015 02:44 AM
OpTicaL
09-16-2015 11:25 AM
Quick Reply: My ACC Fuse Keeps Blowing....Help
