Need help finding the Neutral Safety Switch wire.
Old 03-01-2004 | 02:50 PM
matchbox's Avatar
Default Need help finding the Neutral Safety Switch wire.
I found the Vehicle Speed Sensor wire. It is behind the glovebox in the 2nd connector from the left that is plugged into the computer. I need to find the NSS. I know it is a black wire from searching the forum, but they didn't state where.
Thanks
Matchbox
Dave :D
Old 03-01-2004 | 03:36 PM
matchbox's Avatar
Bump- I'm installing my Viper alarm with remote start tonight.
Matchbox
Dave
Old 03-01-2004 | 06:29 PM
dickpeter's Avatar
Which viper are you putting in?
I am looking at the 791xv.
Old 03-01-2004 | 06:40 PM
matchbox's Avatar
Default 5-speeds have no NSS...
I just talked to a Scion tech. The automatics have a nuetral safety switch the 5-speeds don't..
I have a viper 800 ESP with remote start two window modules, 820m CAR*COM ( I can call my viper from anywhere and remote start , or any of the functions) 2-way microvave sensor. I went with this one because it has a 7 channel reciever. I can control my under car leds , throw sparks from my remote and control my airbags , etc from the remote or from a phone.
The range on the new lcd remotes is questionable. It all depends on where you mount the ant. Also, dont expect to be in a mall and the alarm page you if you get broken into. We have sold a lot of them I just like the older small remotes and replacements dont cost as much as an alarm.
Matchbox
Dave
Old 03-02-2004 | 02:15 AM
DenZinz's Avatar
just ground the wire... If not, ill look tomorrow when I get to work..In the meantime, use a multimeter and check for ground when the shifter is in park...You can probably find it at the switch by the shifter.
Cadillac15
01-29-2015 08:34 AM
gularti
12-04-2014 02:21 PM
randode
44
06-29-2004 05:19 PM
andergtr
27
01-08-2004 06:55 AM
