Optima Battery power distribution system mod - Toy xBox
Old 02-08-2005 | 05:02 PM
Toy_xbox's Avatar
Default Optima Battery power distribution system mod - Toy xBox
Batteries and wires to me have always been an eyesore when customizing cars, at least on RWD cars you can relocate them to the trunk and get the extra benefit of weight for more grip. Well in the case of the xB and it’s FWD no luck and I have to much in the back already.
I knew about the Tsunami battery power distribution top for the Optima and decided to try it out. Like always I had to mod it out to work like I wanted it to and to carry my BCP theme I am doing in the engine compartment.
For this mod I wanted to maintain the factory fusible link box (Red Square Thingy) and try to maintain a factory look and function as well.
So using my favorite tool the Dremel XP400 (this dremel is the cit!!! ) I went to work on it first I disassembled the piece and had it painted to match the BCP. Then I drilled and tapped the negative distribution block to be able to transfer my HKS grounding wires over for the grounding system.
Next I had to fabricate a side mount system to accept the factory fusible link box and maintain use of the positive terminal cap. After two attempts and $20 for an additional cover to mod I have a clean cover that snaps on correctly. I also used some Mallory Ignition pro wire separators to keep all the grounding wires grouped together for a cleaner looking install.
The part that I really liked the most is that I no longer have to have that ugly looking top battery mounting bar. Again thanks to my trusty dremel I modified a set of bottom mounts and was able to secure the battery at the bottom for a much cleaner looking battery install.
Overall it was time consuming my mods usually are I say this is about a 10 beer project 5 for prep and 5 for install. I like the appearance that it has now, but I am working on a remote AC to DC power connection underneath for shows and going to route the positive power cables better for appearance only. I recommend this mod but only to those that have some skillz and will maintain the factory fusible link system; it is there for safety and to protect your car form fire foo's!
Before:
After:
Unmodified:
Old 02-08-2005 | 05:15 PM
DJ_X_Trodinaire's Avatar
looks like a tight fit but it sure looks great!
Old 02-08-2005 | 06:14 PM
Minsk99's Avatar
Nice mod! I always thought the Tsunami battery power distribution thing looked dope.
Old 02-08-2005 | 06:19 PM
Minsk99's Avatar
Where did you end up putting your catch tank? I didn't see it in the after picture.
Old 02-08-2005 | 06:35 PM
Tamago's Avatar
can the optima be mounted on it's side?
Old 02-08-2005 | 06:37 PM
Toy_xbox's Avatar
Still there just did a tight shot of it cause my engine compartment is dirty from the road trip to NorCal for Import Motion
Old 02-08-2005 | 06:45 PM
Tamago's Avatar
nevermind, just read up on em.
my battery is going under the car ! back by the ABS distributor
Old 02-08-2005 | 06:51 PM
Toy_xbox's Avatar
You might want to check out either one of the front corners... I know a guy who is running a optima on the driver side front corner and a Short ram intake... I was thinking about removing the Washer bottle (don't have wipers) on the passenger side and running a second battery there for shows
Old 02-08-2005 | 06:58 PM
Tamago's Avatar
nah, i'll put mine under the car better f/r weight dist.
Old 02-09-2005 | 02:07 AM
oneslowxa's Avatar
looks good! is your battery still tied down?
Old 02-09-2005 | 02:22 AM
aarontrini85's Avatar
what does this thing do?
Old 02-09-2005 | 04:46 AM
oneslowxa's Avatar
it's a ANL fuse holder attaches directly on the battery, it's mainly an aesthetic product, but a very cool one in my opinion.. it also beats having fuse holders screwed into your car, the only drawbacks are that they are designed to fit on a select amount of batteries...
Old 02-09-2005 | 03:27 PM
Toy_xbox's Avatar
I can say that IMO it actually holds better now with the bottom mounts.
Old 02-09-2005 | 05:50 PM
SuperCrunchyAction's Avatar
How does it hold better? It's either secure or it isn't.
Old 02-09-2005 | 05:53 PM
Reign_Man's Avatar
dude thats really cool....i didnt know they made something like that
Old 02-09-2005 | 06:07 PM
squirrel's Avatar
Man, I saw that mod in person, and always, Dave's work is crisp and clean!
Old 02-09-2005 | 06:56 PM
Toy_xbox's Avatar
When using the factory top mount you can move it front to back even when very tight it can be moved. With the bottom optima mounts they contour to the round section as well as flat on the side so no movement and the 3/8" bolt is only 1.5 inches long compared to the 1/4" J bolts
Thanks Brad ya know I have to keep up my rep
Old 02-09-2005 | 11:54 PM
J_A_Trevino's Avatar
looks clean, i like it. is there anyway to get rid of that red box thingy onthe + terminal?
Old 02-10-2005 | 03:32 PM
Toy_xbox's Avatar
I can't recommend it because of the safety issue that the fusible link provides for the electrical system and possible fire if it is bypassed and/or removed.
Old 02-10-2005 | 03:51 PM
Fujiz_xb's Avatar
sIcKsCiOnS
looks swwwweeettt.
Quick Reply: Optima Battery power distribution system mod - Toy xBox
