Optima Battery power distribution system mod - Toy xBox
Old 02-10-2005, 03:53 PM
J_A_Trevino's Avatar
Originally Posted by Toy xbox
Originally Posted by _666_jesus_999_
looks clean, i like it. is there anyway to get rid of that red box thingy onthe + terminal?
I can't recommend it because of the safety issue that the fusible link provides for the electrical system and possible fire if it is bypassed and/or removed.
thanks for the heds up on that, im glad i asked before jumping right in.
J_A_Trevino is offline
Old 02-10-2005, 04:14 PM
Lonely_Raven's Avatar
VERY well done, and I'm hard to impress after all these
years!
I'd love to do all that, but I don't forsee me going with a
big stereo anymore. I've sort of out grown that a little bit.
We'll see what happens after I see some other xB with
nice systems....I'll probably fold and start building again! LOL
Lonely_Raven is offline
Old 02-14-2005, 03:29 AM
what exactly did you use to do the bottom mounts?
Old 02-14-2005, 02:56 PM
Toy_xbox's Avatar
Good luck
The battery came with bottom mounts for GM cars if you look close at the picture towards the bottom you will see the black "V" shaped bracket and one 3/8" SS bolt. You will have to modify the driver side bracket still using the J-bolt.
Everything is a tight fit so you will need to have a good eye and patience to get the driver side mount to work properly.
Good Luck
Toy_xbox is offline
Old 02-14-2005, 03:13 PM
thanks for the info, i had seen the gm mount in the picture but was unsure where you had that bolt mounted to. also, on the drivers side i will hve to make my own bracket or modify the j bolt? and if it is just the j bolt wht does it hold on to? thanks again.
Old 02-14-2005, 03:25 PM
Toy_xbox's Avatar
I will try and get a close up pic tonight...
Toy_xbox is offline
Old 02-14-2005, 04:17 PM
thanks buddy!
Old 02-15-2005, 10:29 PM
Toy_xbox's Avatar
Originally Posted by Minsk99
Where did you end up putting your catch tank? I didn't see it in the after picture.
Here is a better pic after I cleaned the engine bay up...
I tried to get a shot on the driver side but it was too tight... however this shot shows the passenger side. All you have to do is dremel one to fit on the drivers side and use a shorter J bolt. I cut a OEM "J" bolt and ran new threads on it. (TIP) I used double sided VHB tape to hold the mount on the battery so I could install it easier with the "J" bolt on the drivers side...
Toy_xbox is offline
Old 02-16-2005, 07:44 PM
unlmtdndeavor's Avatar
looks great. wats the pricing on one of those?
unlmtdndeavor is offline
Old 02-16-2005, 07:52 PM
Toy_xbox's Avatar
I think it was $125 - $150 not sure to be honest... Anyone who sales Tsunami stuff should be able to get this shipped to you, if you can't find it on the NET...
Good Luck,
Toy_xbox is offline
Old 02-16-2005, 09:28 PM
they have it on parts express for $150
evolving_machine
10-21-2023 01:16 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
foxSCION
18
01-22-2004 05:43 AM
Quick Reply: Optima Battery power distribution system mod - Toy xBox
