orange vvt-i engine cover
I swear somewhere I saw an engine cover in orange that was like the stock black or the carbon fiber aftermarket one. It has the "vvt-i" in raised lettering and all, but I'll be d@mned if I can find it anywhere anymore.
Anyone know what I'm talking about, or am I thinking of one of the colored aftermarket Honda valve covers?
Any info or links would be welcomed!
Stylis, or anyone else, how involved is it to paint something like that and do it the right way (as far as time, money, other obsticles)? Never worked with auto paint before, but that orange engine bay looks real tight, wouldn't mind something like that for myself.
Some people sanded their engine cover before painting. Some also used paint adhesive so the paint would stick better...
Re: orange vvt-i engine cover
hey bro...were at in Indianapolis? im on southwest side off kentucky avenue
I sanded mine with 600 grit emery cloth then I cleaned it with alcohol. Taped out the letters and symbol and sprayed many light coats of Dupli Color Chevy engine orange.
Check out my profile :D
this need hight temp paint?
for you guys who painted this yourself. Does the engine cover need high temp paint?
I have a plastic primer from home depot.
then I plan to paint it flat army green to match my camo.
but it is reg spray NOT high temp paint. will it come off?
thanks
thanks
Re: this need hight temp paint?
thanks
thanks
thanks
thanks
I'll let the wife drive first in case it explodes...
...and I think the mechanic needs to buy you a new one.
Personally I would use high temp paint if you want it to last. It is suppose to hold up stronger against heat and time. You could get some touch up paint from a dealership or on the internet. Just a thought...
Any of the 500 degree "engine enamels" will work great. The heat load isn't a problem, so really any flexible spray paint should hold up fine. I mention "engine enamel" because a) it is acrylic enamel and lays out really wet and shiny and holds gloss best of all spray bomb paints. And b) it comes in a very hot orange among several other colors.
BTW, Krylon is now mass selling "fusion" spray paint guaranteed to bond to plastic. If it works on molded milk bottle plastic patio furniture, it should be surer bet yet on a Scion valve cover. And "32 colors" to choose from. Can't beat that for convenience. And you know, Krylon junk sprays out smooth and sweet as a rule. I expect Fusion holds to their long held quality standard for easy no-drip spraying.
Engine Cover
I had mine done at a friend's body shop. It was going to be little more than $50, but he did it for free since it was small. Looks awesome, if you wanna see it, email me and I'll email it back.
airmankevin1
02-14-2018 01:23 PM
2fixA
33
07-30-2004 03:13 AM
