oznium cathode kit questions
Old 10-19-2005 | 12:12 AM
  #41
binhbinh's Avatar
Phil do you know when you will come out with a pure orange?
Old 10-19-2005 | 12:15 AM
  #42
Oznium_com's Avatar
Takes a while, since they're coming from china, and I have to go back and forth with the design. Months...
In the meantime, I've got some orange film that gives a great orange color when put around the white cathodes.
Let me know if you want to try it out.
aim: philbish
or PM me
Old 10-23-2005 | 08:27 AM
  #43
ohyaa69's Avatar
Default Cold Cathode
My sis just got an 06 tC, and she really wants blue interior lighting. I used traditional neon lights in my Blue Tiburon, but Cold Cathode seems the way to go now from what I have read so far :D. Is there anything you can recommend about wiring these Ozonium I will more than likely order a kit from you soon. Any differences that I should know comparing these to just neons. Its pretty much 2 wires right power and ground, and if I want to switch the neons just tap the power somewhere in between right. Also, where can I get one of those Add a fuse thingy's, and wat kind of switch do you recommend for a OEM look, and any suggestions on where they should be mounted. Thanks for all your help in advanced.
Old 10-23-2005 | 09:43 AM
  #44
-Keith-'s Avatar
He sells basicly a kit for the tc... he did it in my car.
PM him he will set u up.
Old 10-23-2005 | 10:37 AM
  #45
pinoystarr's Avatar
Originally Posted by Oznium_com
I've probably got some spare cig plugs laying around, I can send you. Do you need me to prewire everything?
You should always use a fuse. It depends what amp fuse you are currently using. A 3 amp fuse is fine for at least 5 or maybe 6 cathode kits.
how many cold cathodes could i run if i tapped into my cig ligher???
and by kits you mean single tubes????
le me know... i learned so much from this post already...
Old 10-23-2005 | 11:48 AM
  #46
Oznium_com's Avatar
Cold Cathodes are much better than neons. Cheaper, brighter, smaller...
It is power and ground. 2 wires...
Oznium sells an OEM switch right here that would work great for the cathodes: http://www.oznium.com/gsw-45
I've got a scion "kit" if you want that is plug and play, pre wired if you want.
You can get add-a-fuse at some car part stores.
The cig lighter is maybe 15 amps, you could probably run 30 kits, or 60 tubes.
By kits, I mean 1 transformer powering 2 tubes.
Old 10-23-2005 | 04:11 PM
  #47
ChicagosFinest's Avatar
OhioScions
The math on the new cathodes seems to be different.. 4 kit's will blow 5 amp fuses (at least in my car).. but off the cigerette lighter you should still get enough light to blind you..
Old 10-23-2005 | 09:14 PM
  #48
Oznium_com's Avatar
If you wanted to put a large number of cathodes in the car, you're much better off running a dedicated power wire from the battery. If you're using 15 amps of power from the cig lighter, then you can't plug anything else into it or the fuse would blow.
I don't know how many amps it is, maybe 10, maybe 15. You can certainly run more cathode kits on it that you probably want to.
Old 10-23-2005 | 11:20 PM
  #49
ohyaa69's Avatar
How much is this plug and play kit, and what's the big difference really. How would it work if say I wanted to use 4 cathodes, would I have 2 transformers, or is there any way to run them off one. It would be much easier to ground and power one than 2 seperate pairs of wires. Can you just tap the power and ground of one kit, with the corresponding wires of another kit so you don't have to power and ground 2 different sets. Thanks for all your help oznium, you have been a great source of info. so far.
Old 10-23-2005 | 11:25 PM
  #50
OhioScions
I'm blowing 10 amp fuses with my 4 kits.. I think I wired something wrong.. back to the drawing board..
Old 10-24-2005 | 12:05 AM
  #51
Oznium_com's Avatar
$50 for the plug and play kit, includes 1 cathode kit (2 tubes), add a circuit, oem switch, wiring soldered and crimped
You can run a maximum of 2 tubes on one transformer.
You can tap into the corresponsing wires
Old 05-08-2006 | 10:53 AM
  #52
rchan928's Avatar
I just ordered some, lets hope I know how to hook it up right!
Old 05-10-2006 | 05:42 PM
  #53
mushroomdreamer's Avatar
Default fusing a cathode
i read your intresting article on installing cathodes i didnt do it that way but your way is also a good way. i liked it.
i have two transformers with three cathodes 2(cathodes) on 1(tranny) and 1(c) on 1(t) i do have an in line fuse but its those glass ones. whats the diiference between the glass fuse and the wedge fuse?
for those cathodes i have them on an 3amp glass fuse and they popp pretty fast and i was thinking of going to an 6 amp fuse but changing the wire so i can insert a wedge in line fuse holder.
on other cathodes i dont have any fuses and they seem to work fine but i guess i will eventually have to i think i will put a 5 amp fuse on all of them.
what about strobes will a 5 amp fuse work for them?
if anybody can give electrical wireing terms made easy plain english i will appricate it well guys thank you for your time
peace
Texas Neon Toys
Houston, Tx
Old 06-08-2006 | 04:21 AM
  #54
Chapman's Avatar
Question:
Lets say I have 2 kits (4 cathodes). If I were to tap into the cigarette lighter for power, would I still need a fuse? I'm confused when it comes to anything electrical.
And if I were to have the cathode fade in and out like the dome light, will that shorten the life of the cathodes?
Thanks!
Old 06-08-2006 | 04:36 AM
  #55
ok i got it!
for two CC one 1 tranny requires a 1 amp fuse.
two tranny's three CC requires a 1.5 amp fuse.
So for every one tranny and one CC is a .5 amp fuse
so do the math
, one CC .5 amp two 1 amp three 1.5 and so on.
have questions please feel free
Holla back!
Texas T.N.T Houston C.C.
Neon
Toys
peace
Old 06-08-2006 | 02:57 PM
  #56
HeathenBrewing's Avatar
Originally Posted by Chapman
Question:
Thanks!
Like Phil said in bold in his write-up, "ALWAYS FUSE!"
Old 10-14-2006 | 11:58 PM
  #57
i007spectre's Avatar
If I want the lights to come on when I flip the oem switch, no matter if the car is ruinning or off, which fuse should I add-a-fuse too. Also if the oem switch is in the off position is power still being used. I lack any electrical knowledge. Also Mr. oznium man do you have a link to the scion kit on your website. I could'nt find it. one more q will using the music interface make the cc die faster.
Old 10-15-2006 | 05:19 AM
  #58
Oznium_com's Avatar
You could play around with a few of the fuse locations until you find one that is constant on.
But I don't reccomend it, I'd say make it so you have to have the keys in the car. Otherwise you might leave the cathodes on overnight by mistake.
Don't have a link to the scion wiring kit. Put a note in with the order if you want it.
Music interface shouldn't really affect the life of the cathode kit.
Old 10-17-2006 | 04:22 PM
  #59
MikeyShine's Avatar
nice
Old 10-21-2006 | 10:19 PM
  #60
I want to do my footwells. I have seen many xa/xb how too's but not a single tc one. Where did you run the wires, and hang the drivers side tube.
Does the center console need to be removed.
FYI I am using add-a-fuse, and a scion rocker switch.
I am completely horible at automotive electrical work, and any help would be appreciated.
