powered subwoofer recommendations?
I am looking for something simple to install so I figure I should probably go with a powered tube of some kind, can anyone recommend any good ones that don't suck like the bazooka?
BTW: bazooka was top notch a few years back I thought what happened? All I hear is people saying they are not worth the cash.
Originally Posted by KAuss
Get the Kicker, then the Bazooka, then settle for Infinity if you have to..
Infinity sounds like loosely tightened drum...
Processor setup and I had much better control of the bass.
The best thing about the basslink is that it uses less space (more mounting options), more of a factory looking installed item instead of a add-on and to me is just right to hear and feel the bass without going overboard.
I recommend it to anyone who wants a nice looking powered sub solution to enhance their factory system
ive got the infinity basslink mounted in the rear cargo area (up against & parallel to the rear seat...if that makes sense...) i agree that it is a convenient alternative to the Bazooka Tube... it gives a very clean and accurate low end...
if you get it...my only advice is do not have in any way, shape, or form, any expectation / want / or need for a real deep low end sound. that's not what its about...it sounds really clean with almost any types of music, but when you get into stuff like hip hop / rap stuff...the low end is not very satisfying...
good luck!
good luck!
good luck!
good luck!
good luck!
good luck!
good luck!
good luck!
good luck!
good luck!
http://manuals.harman.com/INF/CAR/Ow...SLINK%20om.pdf
I did the input source connection to the basslink from the rear speakers it worked fine. I later purchased the toyota wiring harness for the bazooka to get a factory connection to the head unit and never used it. It would of been a cleaner install but it was working fine the way I originally set it up.
good luck!
good luck!
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Zipo
04-13-2015 03:31 PM
crystaljukebox_com
02-05-2004 05:53 AM
