Problems with RS3200 RKE/Security System Install
I have the wiring harness completely wired into the car but now the headlights, turn signals and drivers side window do not work. I am also unable to get the remote key fobs to lock or unlock the doors (Least of my worries now). I have an 06 Xa and I'm using the correct wiring harness, triple checked the wiring (It's not possible to connect this incorrectly is it? Should be plug n' play, right?) I did notice that the 9p connector on the back of the J/B was loose when I initially tried to start the car but secured it correctly and was able to start the car. I thought I might have popped a fuse but I checked them all and they appear fine. I'm at a loss for what to check next before I call the dealer tomorrow. I'm 4 hrs from home and don't want to have to drive back without headlights or turn signals.
HELP~~~.
I encountered a similar problem. My car is 2006 xA and I installed rs3200 (08586-529730-aa) on it. I am pretty much sure that I followed an instruction manual (TVIP V3 Issue: D 04/09/07) came along with the product. Since then, the power window and side mirror control is not working. The power lock button doesn't trigger the driver door (however, all the other doors work as normal). Of course, my car doesn't any response to a remote control. I don't know what to do in the next step. Before I begin programming the remote control, all other things should work as normal, right?
install the other security system instead of RS3200
Finally, I visited a local auto shop (specialized in audio/accessary) and have them look at it. They did uninstall the kit that I mounted and it works as normal. Then, they also followed the manual instruction and the result is same. I paid $50 for the labor fee and diagnosis. After that, I decided that I have them install the other door lock system and remote control and it works perfectly!
Now, I need to return RS3200 that I guess has defect to a shop I bought. They keep refusing return process. I explained very clearly to them. I am so upset and wasted my money. What should I do!
To anybody who wants to install RS3200 (I think it was not easy and it took almost 6~7 hours. Now, I can do it in 2~3 hours.), visit a local shop and have them install a security kit that they recommended. It would be only $100 including everything! If you want a remote start, it adds $200.
Beesh
01-09-2015 07:30 PM
PTUNING
12-11-2014 09:09 PM
PTUNING
12-06-2014 04:58 PM
TheRedBox
31
12-02-2003 05:53 PM
