Putting a 110 Volt outlet converter in the ashtray area
I want to put a 110 voltage (home) outlet in the ashtray area. i know the idea is a little farfetched but is this possible? Has this been done before? I don't like the ciggy converters. doesn't look clean.
yep. get a dc->ac power converter, hack it apart, and put the plug into the ashtray.
this would require some disassembly of the inverter, some cutting of the ashtray, and some lengthening of the some wires.
thats what i was thinking but i have never done it before and know that these converters come with built in cooling units and that it might interfere with that.
the cooling fans are fine. all your going to want to to is remove the plugs from the housing of the converter and mount it in the ashtray. mount he main body of the converter somewhere hidden and extend the wires leading form the main housing and the plug.
Team Sushi
There's an even easier way. . .
. . . mount the inverter somewhere else, and use AN EXTENSION CORD. Cut the female plug off and connect the (proper) wires to a fabricated outlet. Unless it was absolutely necessary, I wouldn't hack apart the inverter.
I wanna see pics of the first install....anyone, anyone?
they usually have a pretty good heatsink and maybe a fan. make sure you leave enough surface area exposed so it doesnt overheat. also, allow access back to the plug in case you blow the fuse on it
Team Sushi
Originally Posted by Alchemist80
doesnt this all require having something plugged into the cigarette lighter at all times? Id like something that was hardwired somehow.
Team Sushi
And a bit of warning guys. . . make sure all the wires you use are of sufficient guage (thickness and rating) for the length and wattage you will be running. The last thing you want is a fire! AC power can be a lot more dangerous than DC.
I'm bouncing around the idea of doing a 110 outlet in the little plate above the glove box. I think it'd be sweet, but I'm having a hard time coming up with a way to install a 110 outlet on that plate and having it be both durable and professional looking. Ideas anyone?
evolving_machine
02-27-2015 09:53 PM
lunchbx05
12-11-2014 06:13 PM
rcflyer15
12-05-2014 05:15 PM
