removing fog lights and componets
Unplug your battery to be safe.
When you're looking at the fuse panel, on the left side of it there are some relay holders. They look like plastic sockets attached to the side of the fuse panel.
Here's a picture:
http://overboost.com/picture.asp?a=1098&i=DSC09212.JPG
Go to the 2nd one up. Stick a small flathead screwdriver in the hole to detach the relay socket. If you find anything difficult, it will probably be this step. It took me a while to find the little clip that holds it in place. Then you just pull on the relay socket until it comes off. Once you slide it off the fuse box, it should look like that picture.
Note: you will not be able to see the relay until you detach the relay socket. Now, just take out the relay: the little aqua colored thing.
I'm not sure if you can just take out the relay from the back of the fusebox, but if you're lazy, it might just come out without taking off the relay socket. ;)
Here's a picture:
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
carid
01-08-2015 11:33 AM
