Removing silver interior peices
MN Scions
I'll be getting the silver peices in my xB painted soon, but 1st i need to get them out. The ones I dont know how to get out are....
1. window control bezels
2. Silver ring around base of shifter
3. Two pieces on steering wheel
Thanks in advance
Thanks in advance
window controls, get a screw driver and pop it off
silver rinigng - jst take off the whole waterfall and then once thats off push to the side and comes right off
steerring wheel thingy, disconnect battery negative and then theres screws to unscrew before u take them off. NOT disconnectng ur negative battery wire will result in airbag deploying or going off
Good luck
Good luck
MN Scions
were talking xB here, we on the same page?
Also, i'm going to be without the peices on the steering wheel for a bit, if i re-connected the battery, would the airbag go off, or do I have any safety hazards?
Well, I can tell you about the shift bezel. Piece of cake. Remove the center console (unscrew the one screw on the back and lift up on the front. The bezel is clipped in from underneath.
MN Scions
to avoid the risk of breaking the window controls(like I did back in the day) just take the door pannel off, Take out the screw at the handle, and the one in the "cup". Then just pop the door panel off. Then you can safely remove the controls.
The steering wheel is a little harder to do but not to bad. For safety(I never do) disconnect the batt, and undo the the screws that on the back side of the steering wheel. The screws will not come out all the way. Then pull your air bag up, and you will see three wires running to it. Just unplug the black one, but the other two you will need to take a flat head screwdriver and pry up the little yellow tabs before they will unplug from the airbag. And there you go.
Maybe that will help you.
And do this at your own risk. I am not responsible if you break something, ha ha
Here is a good DIY for the steering wheel controls on the gen1 gen2 should be similar
http://www.xbsite.com/forum/howto-re...es-t-1098.html
MN Scions
So removing the door panel will make it easier to get the window control trim out.
Also, is getting the silver ring out that is around the shifter the same for Automatic transmission? Just get the center console out then what? Are there some clips or something that I can pop off?
Yes, clips from what I have read.
I am doing the same thing, painting all the silver accesnt to match the body color.
If you have an auto trans, the floor console can be lifted enough for you to reach under it to unclip the ring. I have read that it is hard to remove the shifter handle. Use a mirror to see underneith.
I have to do this after I uninstall my armrest. Once this ring is removed, re-secure the floor console because the ring should snap back into place without disassembling.
The window controls have a clip in the front and a claw in the back, so you must try to unclip the front without doing damage to the apolstry. If it is too tight to unclip, then remove the door panel. The rear window control covers have claws on both sides, so the door panel will probablly need to come off.
Window controls are just like everyone has said, remove the door panels.
The trim ring around the center shift, again like was mentioned remove the rear screw and then pop off the front. The trim ring can then be removed. If you rotate the center console you can get it around the auto tranny shifter and take it out entirely.
There is a small silver piece that covers the shift button and OD button. That can be removed as well. It takes a small thin flat head screw driver and some time but it can be removed. You will have to remove the OD button once you get the silver cover out.
The dash console can be reomoved once you take the 3 ***** off, remove the 2 screws behind them and pull out.
The speedo cover can be removed if you removed the tiny phillips screw on the underside where the idiot lights are. Then just pull out.
The steering wheel is just like was mentioned as well. Although, the sliver trim pieces are riveted on ... so you can either drill out the plastic rivets or just tape off the center air bag section. I taped mine off and drove around without an air bag for a week while the interior was being painted.
