Scion xb factory crossover
Old 08-24-2005 | 10:37 PM
Toydriver00's Avatar
Default Scion xb factory crossover
Is somebody able to tell me where the factory speaker crossovers are located? Do the speakers have capacitors built into them?
Thanks
Old 08-24-2005 | 10:52 PM
GLN305's Avatar
Stock tweeters have a capacitor built on them. The door and rear speakers play full range. If you need some crossover caps 200Hz 6db/octave then go visit Wal-Mart, they have them for about $7a pair. I have them on my JL's in the dash and they do the job perfectly.
Old 08-24-2005 | 11:10 PM
Thanks-
I was thinking about using my factory wiring, and I just wanted to know if I would have to take a crossover out.
Old 08-24-2005 | 11:17 PM
Newtmaker's Avatar
The dash speakers and door speakers are wired in parallel. You need to keep that in mind when/if replacing factory speakers.
I replaced all my speakers with better quality Pioneers and I left the capacitor off when hooking everything up. Because of the parallel wiring and the new speakers being 4 ohm speakers my dash speakers play pretty loud as compared to the stock setup. So far they have not exhibited any distortions that I can detect. I was told that as long as they don't distort that I would not really need bass blockers. I seldom set my volume higher than 25 or 26 however. If I went much higher I might want/need the blockers.
Walt
Old 08-24-2005 | 11:20 PM
GLN305's Avatar
When I replaced my speakers and amplified them, I opted to use the factory wiring also. I honestly don't think that I would have been able to tell a difference if I ran a wire straight from the amp. As far as the capacitor, it's just on the tweeter, there is nothing "in line" per say on the actual speaker wires.
Old 08-25-2005 | 01:12 AM
Thanks for your inputs everyone. I am replacing my 4" and fronts with components and rears with 5.25s.
Old 08-25-2005 | 04:53 AM
mojoman's Avatar
Where rae the dash and door speakers wires joined together....that would be a perfect place to install the aftermarket Crossover that comes with seperates.
I want to do the same thing but cannot get info as to ideal location to mount crossover door or dash) to be able to use factory wiring.
Mojoman
Old 08-25-2005 | 04:56 AM
Sciond's Avatar
Mojoman
why?...... you ccn put chokes closer to dash speakers......and pla the door full range use a different crossover point..........
Old 08-25-2005 | 05:04 AM
mojoman's Avatar
The question is if you hook up the aftermarket seperates (6.5" in doors and 4" in dash) the supplied crossover needs to be installed between radio and speakers.
I am wondering where the factory wiring for the dash and dorr meet...which woudl be easiest place ot mount crossover.
Mojoman
Old 08-25-2005 | 11:02 AM
I would have to agree with that. I will have to find it.
Thanks
Old 08-25-2005 | 11:56 AM
mojoman's Avatar
Toydriver00,
Are you replacing teh 4" dash and doors with two sets of component seperates are just one like me? What brand/price are you buying?
Thanks.
Mojoman
Old 08-25-2005 | 03:20 PM
I am replacing the fronts with a single set of components. Polk Momo MMC6500. I work for circuit city part time so, my price is a lot lower than even what you find on eBay. The tweeters will be in dash and 6.5s in the door. I am also installing a 2-way alarm.
Old 08-25-2005 | 03:41 PM
ack154's Avatar
Moved to ICE...
Old 08-26-2005 | 12:00 AM
mojoman's Avatar
Toydriver00,
Can you please let me know what you find out when installing them. SOme pics here and there would be great if you do not mind. What adapters/brackets are you going to use to mount the 6.5" speakers in door...scosche?
Thanks
Mojoman
Old 08-26-2005 | 01:40 AM
I am using SAT6 adapters in the front. The rear---had to be "modified". I have the rear speakers in now. I used a dremmel and cut a small section of metal out and the speakers slid right in.
herwig
Scion tC 1G ICE & Interior
03-23-2015 05:19 AM
lunchbx05
12-29-2014 08:53 PM
minter66
12-15-2014 02:45 PM
lunchbx05
12-11-2014 07:13 PM
ScionLife Editor
12-07-2014 12:58 AM
