Scion xB sports pedal....does it go over the standard one ?
Hi...maybe this is a strange question for you guys that are used to modify cars, but I'm new to this and having fun with it. I saw the silver sports pedal (Scion.com) and would like to know if they are easy to install...do they go over the stock ones ?
Yes, it slips over the accelerator pedal. The brake (and clutch if you have one) are replaced by the new ones. Look around, you should be able to pick them up cheap. I have the silver ones and like them. Good luck.
Oh, and yes, with a little soapy water, are easy to install.
Hey, thanks 1epoXyBox, it really looks nice, the picture helps a lot. I have an automatic. I just bought it at ebay a few minutes ago....$37.50 OBX silver sports pedal, same as yours. It seems that the accelerator is just a slip and the brake I'll have to do some assembling, is it easy ?
The brake is a little easier. Just take the rubber pad off, and use the same method as the accelerator to get the new one on. I grabbed the picture below from this site to help you visualize it.
I think that the pedals may have been my first mod too. Make sure to check out the Tech section under Features. There are some really good do-it-yourself (DIY) projects that you may want to try. The air filter is a great one. Good luck!
Originally Posted by Tialian
I got the blue ones from the dealer and have had no problems with them, the dealer even put them on for free. Why should I do it when they will? ;)
They look great and I'm 100% satisfyed.
hampton1100
01-02-2015 08:13 PM
umnitza
12-01-2014 06:26 PM
ScionLife Editor
11-25-2014 03:00 PM
