Stock 6 Disc Head Unit Error 4 ???
Old 05-02-2006, 08:01 PM
Defined3
WRxB's Avatar
Default Stock 6 Disc Head Unit Error 4 ???
Tried to search with no results so :
I was flipping through the disc changer today & when I found the disc I wanted & Error 4 appeared on the screen & the disk wouldn't play. Tried to Eject with no luck, tried hitting FM then back to Disc no luck, Error 4 !!! I got home ran in the house real quick came back out started the car & the disc ejected. I put the disc back in & it played & haven't had a problem since.
Anyone else ???
Anyone know what the hell Error 4 means ???
If it happens again is there anyway to fix it other than rebooting the player ???
Thanks
WRxB is offline
Old 05-04-2006, 02:34 AM
Defined3
WRxB's Avatar
So nobody has had this problem ???
Hmmm sounds like a quick trip to the dealer then.
Well at least it hasn't happened to me again.
WRxB is offline
Old 05-04-2006, 04:45 PM
Scion Dynasty
mad-sciontist's Avatar
I had the problem in my old xA, its happened to alot of them... The only thing you can do is like you said, take it to the dealer... They will order a warranty replacement... Thats what they had to do for me when i kept getting "Error 4"
mad-sciontist is offline
Old 05-04-2006, 07:42 PM
Defined3
WRxB's Avatar
Did they tell you what caused it ?
Thanks
WRxB is offline
Old 05-04-2006, 08:03 PM
Scion Dynasty
Basically, it got jammed. Thats all they told me. They had to ship it to Toyota, and they mailed me back my CD's...
Old 05-05-2006, 12:03 AM
Defined3
WRxB's Avatar
Thanks for your help, I am going to take it to the dealer & see if I can't get it fixed before it becomes a bigger problem.
WRxB is offline
Old 05-05-2006, 12:10 AM
Scion Dynasty
No problem, hope I helped... lol
Old 05-05-2006, 12:23 AM
Defined3
WRxB's Avatar
You helped because I didn't have a clue what the hell was wrong with it. At least i now know it was a jam of some sort. I was clueless !
WRxB is offline
Old 05-05-2006, 07:37 AM
Psyco565's Avatar
Yea, happens to a ton of people. I had to do it once already.
Psyco565 is offline
Old 05-05-2006, 08:33 PM
ricktoyota73's Avatar
Be sure not to use cd's that you made with stick-on labels, damaged cd's, or discs that are smaller than normal or odd shaped discs.
There isn't much clearance in those changers. I am still dumbfounded by how the in-dash 6 CD changer works.
ricktoyota73 is offline
Old 05-07-2006, 03:24 PM
xb-scion-barney's Avatar
I have a problem with error 4 but now it won't come out with me shutting off or turning the car back on. Now my scion is not cover under warranty need help. Not mechanical incine.
xb-scion-barney is offline
Old 08-07-2006, 02:59 AM
ganske03's Avatar
I had the same problem with the error 4. I got mine replaced under warrenty as well and they said it was because of burnt CD's. They said they are thicker then normal CD's which jammed it but I think he was full of ____. If it happens again I am getting an aftermarket CD player.
ganske03 is offline
Old 08-07-2006, 03:32 AM
J_Bomb's Avatar
The dealer found the error 4 problem on mine and then explained to me that it was an "ID ten T error" and will be fixed under warranty. What does that mean?
J_Bomb is offline
Old 08-07-2006, 04:04 AM
Blacklisted's Avatar
does anybody know what error 3 is?
i cant eject discs or anything
it wont even play cds
ive searched the board and most everybody's having error 4 problems
Blacklisted is offline
Old 08-07-2006, 04:44 PM
ganske03's Avatar
I dont know what it means but Im pretty sure your whole changer is junk. My as well not waste anymore time waiting because nothing is going to change. Scion really needs to work on this issue!
ganske03 is offline
Old 08-07-2006, 05:20 PM
this is the first time its happened to me
i just called the dealership and the service guy was like
"oh ok just bring it in and we'll have to order you a new one" like it was nothing
Old 08-07-2006, 05:45 PM
Crispyxb's Avatar
It worked just fine before I took it out, I actually regret taking it out. It worked better than my new head unit.
Crispyxb is offline
Old 08-26-2006, 08:10 PM
OooThatsSharp's Avatar
Thats funny dude. An "ID Ten T" error. Look at it like this - "ID10T" or "Idiot". They so made fun of you, and you had no idea. Sorry dude...
OooThatsSharp is offline
Old 08-26-2006, 09:12 PM
avfrog's Avatar
I just bought my 05 Xb....LOVE IT... I just figured out that my disc changer also says error 4. I am going to take it up to the dealer today. Although, from what I hear here. I might just buy an aftermarket.
avfrog is offline
Old 08-27-2006, 02:30 AM
J_Bomb's Avatar
Now in effing p.issed. Im going back to the dealer with a weapon tomorrow. Nobody makes fun of me.
J_Bomb is offline
Quick Reply: Stock 6 Disc Head Unit Error 4 ???
