Stock Stereo Keeps Going Out
I'm assuming it's either a lose wire or it's grounding. I was just going to pull the stereo out and check the wiring. Even when I hit the power button it still persists to crackle. I do have some EL wire around the bottom of my dash but wether it's on or off it still does it.
Also when I take left corners hard it fixes the problem and then rights make it worse.
Then if it continues I'm going to Bring it back to the dealer.
Has anybody else had this problem?
reply
You know I've had the same problem but only when I play the stereo loud. I hooked up my 2 Cerwin Vega 10's with a 1000 watt amp. I tapped into the back panel speakers to a Ohm to RCA converter then to my amp. When i hit a certain frequency it has a habbit of turning off with no option of turning on. I have to turn the car off then restart it to make it work. I figured it was a anti speaker damage feature. But I don't get it all the time. So ya I have that same issue. When I'm driving on the freeway I gotta put it in Neutral turn the ingnition off the turn the car on, then put it back into drive. that my freeway option. LOL let me know if your dealer finds a solution for that problem. I'll prebably try and fix it too!
Haha yea and I also tapped into my back left speaker.
And I also put my car in nuetral and turned it back on.
But the stereo will stay on and persist to crackle . I should probably bite the bullet and get one of those harnesses off of ebay.
Re: reply
darkshadowofxdeath
12-03-2014 06:59 PM
koreysbox
03-11-2004 12:26 AM
