SUB/AMP Wiring Help... any Audio GURU's?!
I got the Audiobahn 2150 high current amp which is one ohm stable.. and gonna push 6 10" MTX Thunder8000 subs..
Can someone help me out with the best wiring diagram for this setup..
Thx,
David
Thx,
David
the info on the subs are....
T8104A
10" Subwoofer
Impedence: 4 Ohms
Frequencies: 24 Hz-150 Hz
Power (RMS/PEAK): 400/800
Sensitivity: 84.2 dB
Voice Coil: 2 1/2"
Magnet size: 102 oz.
Mounting depth: 5"
T8104A
10" Subwoofer
Impedence: 4 Ohms
Voice Coil: 2 1/2"
Mounting depth: 5"
um...i'm not an audio guru but i will throw out an idea.
4 ohm subwoofer x6
1 ohm stable amp x1
ok. i think you can use a series-parallel configuration and for the speakers and come up with a 1.5 ohm load to the amp, which will be loud and shouldn't be a problem for the amp you are using at all. i'm just guessing though. i'm sure the real audio guys can answer this better.
4 ohm subwoofer x6
1 ohm stable amp x1
Re: SUB/AMP Wiring Help... any Audio GURU's?!
PM Chris (autosound),he should be able to give you some help w/ the set-up. He owns his own shop in Hayward.
Chris had the black xB saturday night w/ the chrome 19s parked w/ louie and I.
squirrel
If you parallel all 6 subs you will get .66 too low for your Audiobahn amp.
If you do a standard series/parallel, you will only obtain a 2.66. which will not optimize the amp
If you do a combination of 2 subs series + 2 subs series + 1 parallel + 1 parallel you will come out to 1.5. which still wont optimize the amp.
so its your choice. I would ditch 2 of the subs and just do 4. You will get more power out of 4 than the 6 considering the ohm load.
hold on. you don't have to push the amp to it's maximum limits to get the best sound. even if you were to run all the speakers at 2 ohm or even 4 ohm, you could get it to sound really loud. i think 1.5 ohm would be fine. the speakers he choose aren't the best for that amp. a better choice would have been 6 JL 6 owhm speakers to run into a 1 ohm configuration in series-parellel. anyway, i'm not here to judge. i'm just saying that it will sound good even at 2 ohms. lots of amps are 1 or even 1/2 ohm stable, but that doesn't mean you have to run them that way. just my non professional opinion, of course.
Also important is your voltage. What is that amp rated at? because anything over 1000watts you really should concider getting an additional battery for the best performance. If that amp you are talking about is a Class D, than be sure to keep the voltage up on that or you will blow the amp due to lack of voltage.
WOW.. thx alot guys...
I am running all these subs on one amp for the meanwhile. Im gonna get another amp in the future.
My previous system in my Scion was 4 10" JL.. and wanted more beat (Used from previous car)! Sold that system about a week before the meet. Had 2 10's at the meet.
Thx again,
Dave
Thx again,
Dave
hmm.... how did u guys come up with those numbers?!
Could someone give me the formula on knowin how much ohms ur running?
Dave
Dave
paralleling 2 sub
........(r1xr2)
R= _______
........(r1+r2)
for paralleling mulitple subs
.................................1
. .... ____________________________
R=
.............1...........1.........1...........1
..............__ + ___ + ___ + ___
.............. r1..........r2 .......r3 .......r4
Series is
R = r1 + r2 + r3 + etc., +etc.
the periods are just for spacing purposes
XB06
15
10-01-2022 11:24 PM
Beesh
01-09-2015 07:30 PM
