SUB WIRING SUGGESTIONS
Ive got a infinity kappa perfect 10d vq in a sealed box and a kenwood kac-7201
2 channel amp bridged to the sub.
is there any better way to wire this setup?
thanx.
thanx.
Re: SUB WIRING SUGGESTIONS
thanx.
thanx.
Originally Posted by RaginCajun
If you unbridge the amp you will loose power. Just leave it wired like it is and install.
I'm with Mark on this one (and others). There's too much random, incomplete, or just flat out incorrect advice given on the boards.
I know people want to help but if the advice is wrong or incomplete it can be much worse than no advice at all.
POWER RATINGS
- Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
- Maximum Output Power: 800 Watts
- Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
- Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
im with chadfo and mark. however, you might wan to consider this, if your sub is DVC(dual voice coil) and your amp is two channel, you could wire each voice coil to an individual channel(like you were running two speakers) that way youre not running your amp less than 2ohms. like mark said though, if you run that sub in parallel, youll fry that amp and bam, there goes your dough. best bet, get another sub and run them both in series and then parallel the leads so that the amp sees a 4ohm load or just run the SINGLE speaker with both voice coils to their own channel. good luck.
^^^^^ I stand corrected. just ou t of curiosity, why do some folks, here and at other audio forums, give the suggestion to run both coils on a 2 channel? i didnt realize there was potential for different phasing on each coil.-thanks
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
