Tach needle stuck
Originally Posted by Rivulent
Did you touch your needle? This happens when you dismantel the dash and forget to rest the needles where they need to be rested.
There is a cure for this. A Smith & Wesson 357 Magnum.
Sounds fishey to me. Changing the air filter should have had no effect on the tach at all. Sounds like something you may want to have a service tech take a look see to diagnose the problem.
![Silly](https://www.scionlife.com/forums/images/smilies/icon_stopit!.gif)
[quote="über-xA-RS2"
Sounds fishey to me. Changing the air filter should have had no effect on the tach at all. Sounds like something you may want to have a service tech take a look see to diagnose the problem.[/quote]
I really didn't think it did.....I believe it is in the guage. I am so leary of a dealer screwing something else up or leaving me with a dash rattle, that I am afraid to let them touch it. But that may be my only choice.
By the way, is there an easier way to change the air filter? Did I have to disconnect a couple of hoses to change it?
![Roll On Floor Laughing](https://www.scionlife.com/forums/images/smilies/icon_rofl.gif)
Don't give me any ideas
![Raise Eyebrow](https://www.scionlife.com/forums/images/smilies/icon_eyebrow.gif)
You can probably easily fix this yourself, I did after screwing with the speedo a few times. THe needle gets a little loose, and you have to turn it COUNTER-clockwise to the right location. If you twist it CLOCKWISE, it just gets loose and goes back to its original location. SO just dismantle it easily, and then twist the needle back down to 0 when the car is off.
If you've never taken it apart, my advice would be to take it to the dealer because if you go taking this apart and end up breaking something, the dealer could refuse to help if they find you tampered with it.
hmmmm....I may just try that. Not any more scary that having some dealer klutz scratch up the dash and introduce some fun new rattles.
Thanks Grime!
no problem, and its a lot easier than going all the way to the dealer and waiting for hours.
Hey, I just took a drive and guess what?......the tach is fine now. I didn't do anything to it and it is back to normal.
I suppose it will happen again sometime, but as long as it works right most of the time, I am going to leave well enough alone.
Thanks for all the good advice.
Sean
Originally Posted by Tomas
Things like this is why we have warranties... :D
I am grateful that the xB has had such high quality that I haven't had the need to go to the dealer
MrMeanor
09-28-2019 04:37 PM
SJMiller
09-12-2015 06:33 PM
BlingSlade
09-05-2015 08:52 AM
