For those that have done the Navi swap...
How does the sound quality compare to the factory system? I'm considering doing this swap, but I definately don't want to end up with a worse sound system than I started with!
Also, can you still use the factory Bazooka subwoofer in the xB with this swap?
Any info you can give me regarding how you like the swap after-the-fact, I would greatly appreciate.
Thanks!
Jeremy
Thanks!
Jeremy
I thought the sound was better after the swap, i had more control over it with the new unit...x-over points and gains.
the bazooka tube shuold be able to work (if it was hi-level input, or has a hi-low converter. don't know 'cause i don't have one....)
I guess I should have specified that I'm referring to the '04 Camry Navigation Unit; I assume that is what you are referring to as well!
How do you like the unit overall? It looks very nice, does it funtion well too?
Jeremy
Jeremy
Jeremy
Jeremy
HTH,
JT
Originally Posted by dgHotLava
nope, pioneer navi....
sorry...
sorry...
JT
i went from the stock (RS1.0 xB) radio, to the avic-n1...
never had the toyota navi....but i do work on new toyotas and i like my avic-n1 better (it has the potential to do more...)
the newer toyota nav's have dual dvd drives. one for the nav rom and the other is for movies and music. its possible to fit the factory nav in our scions. keep in mind that some camrys has an external amp (jbl) they are all dual din but width and and height is slightly different from differnt models. i'm a big fan of the avic n1, but after seeing the nav from the 04 solara.... its freakin amazing!
Is this possible for us tc owners. I would love to hook up nav in my car since i drive all the time.. Well I pretty much know where im always at anyway. But would still love to have it withought loosing the factpry look also.
Can you still run and amp kit for this headunit also cuz I wanna put my subs in
How much would that cost to have done wit everything.
Is it hard to hook up yourself if you electronically inclined.. I mean I can install head units/systems.. what ahve you..
And what Bay area?. Im from south jersey.. 10 minutes outside of philly.. town called " deptford"
I was thinking about the nav options and what I would like is an indash touchscreen that I could control tuner, cd, dvd and nav through. Figured the dvd/cd, MP3 player could be placed in the cubby hole. Would have to have preouts for amplification.
I would like to be able to control everything through the screen or an infrared remote and just use the player to swap out music. Would also consider a disc changer in addition to the cd/dvd player for roadtrips.
What size screen will fit in the stock double din location? I saw someone with 8.5" screen. Is that the largest that will fit?
I don't know much about what is avail through factory options, which is why I'm asking for info. Have no problem going aftermarket, I'd just like it to look clean and as stock as possible.
Originally Posted by TXboxdriver
ElChupacabra
10
09-21-2006 06:42 PM
ramen
41
10-05-2005 06:27 PM
