Tuning mrd-m501 amp/diamond audio d6 sub..
Originally Posted by LavaBox_v1
You want to set it at 80hz ... that is what I have my mrd-m501 set at ... Thats the only setting I can remember off the top of my head ... Also what headunit do you have ... Alot of your tunning will be comming from the headunit ... My 9835 has built in crossover for Front, Rear, Sub and a full EQ most of the sound quality comes from tweaking thoes ... the amp is just to fine tune a little more ... If you have a good headunit with crossover and eq you will want to adjust that first and then adjust the amp.
i got your pm and ill send you that info i found tonight. It is a document with descriptions of what each setting is for. It helps and you can tune it for how you would like it.
BTW 80 is good, i retarded out and forgot the 501 is a mono amp for subs usually. One of those days
Yeah its a mono 500watt amp ... You didn't really retard out becasuse also depending on what sub he is running also could be what freq. he needs to set it at ... I know for my Alpine Type-X it is set at 80hz for best sound ... that could change for each sub but 80hz is a good place to start!
Call diamond audio and ask them ... they will know their subs best ...
i called diamond and they told me there subs sound best at 60-65hz lpf.. Heres a problem though, the lowest setting on my head unit (alpine 9831) is 80hz, but the amp can go much lower. Also a guy at tweeter told me to turn defeat on and let the amp process everything rather then head unit. When I do this, for some reason i get no subwoofer...
AngHellicTc
Scion tC 1G ICE & Interior
10
04-22-2009 01:26 AM
tbone587
11
01-23-2005 05:08 AM
