TWM Performance Short Shifter Install (xA/xB)
Old 10-20-2004, 01:02 PM
xAlex's Avatar
twm makes a short throw for the tC
xAlex is offline
Old 02-01-2005, 06:16 PM
MicroVan's Avatar
This was a great HOW TO!!!
Installed mine in 1 1/2 hours! Just like mikochu said, the hardest part was the Metal Clip and the Plastic Ring! That alone took abot 25 minutes each!
Other than that, IT WAS A BREEZE! I was a bit confused how the spring should go back on the assembly, but after looking at the tC shifter install I saw what I needed to do.
My hint is to look at the spring before you take it apart! Other than that I can't wait to go do some driving now
Thanks mikochu!!!!!!!!
MicroVan is offline
Old 02-01-2005, 06:20 PM
MicroVan's Avatar
Oh btw,
I ordered mine from ptuning.com also.
Ordered it on Friday 01/28/05 at 5:06pm and it was at my door the NEXT DAY at 11am!
Cost me $116.00 shipped, it would have been $110.00 but since I live in VA, I was taxed 5%.
MicroVan is offline
Old 02-16-2005, 04:29 AM
scionscorpion's Avatar
Well i got my short shift kit for 44$ on ebay brand new will see how it works etc....btw i got the hausing too
scionscorpion is offline
Old 02-16-2005, 05:43 AM
Team Sushi
djct_watt's Avatar
sounds like the RS type
djct_watt is offline
Old 04-08-2005, 11:12 AM
Guest
Guest
Posts: n/a
I've seen the "RS Type" short shifters on ebay for around $40.00. What is the differenced between these and the ones like you guys installed(twm or trd)? Is it harder to install? Do they suck ___ compared to the others? Which is the best one to get?
Thanks
Old 04-10-2005, 03:51 AM
ScionxR's Avatar
If i cut the clip off what goes back on to secure it? Or does that clip have to come off the side?
ScionxR is offline
Old 04-10-2005, 05:12 AM
mikochu's Avatar
The TWM kit comes with extra clips...
mikochu is offline
Old 04-11-2005, 12:46 AM
ScionxR's Avatar
anyone know the part # for the clip? im headed to toyota in the morning so i can drive again
ScionxR is offline
Old 04-12-2005, 05:22 AM
ScionxR's Avatar
went to Toyota and they cant order me one. If anyone has the "one way washer" that you have to dremel off to tap out the rod that holds the shift stick on ill paypal them some $$. I heard TWM sends you a pair with their shift rod.
ScionxR is offline
Old 03-22-2006, 01:49 AM
stockfogs's Avatar
Thanks for the tutorial.. 30 mins start to finish
stockfogs is offline
Old 09-25-2007, 03:21 PM
erodsani's Avatar
Hey there. I've had mine for awhile now and have to do a little fix. When I installed it, the retaining ring that hold the shifter down cracked. I fear that it might pop off, so I'd like to get a new one. Should I go to the dealership? Does anyone know where else I can get one? Should I care? Is the shifter wobbly because I didn't put in aftermarket bushings? I could use a little advise
erodsani is offline
Old 04-09-2008, 03:32 PM
erodsani's Avatar
Ok, so I lost the ability to get into 1st and 2nd last night. I have a temporary fix in place, but i need a new part, the circled part below to be exact.
Anyone know a part number for this? I'd hate to buy the whole cage because I really don't need it all. Any help is greatly appreciated.
erodsani is offline
NonStopTuning
06-29-2015 07:42 PM
disaster06
02-03-2015 08:50 PM
disaster06
12-26-2014 03:00 PM
disaster06
12-04-2014 07:05 PM
gularti
12-04-2014 01:21 PM
Quick Reply: TWM Performance Short Shifter Install (xA/xB)
