Volume problems upon installing Alpine deck... somebody help
Heres the basic problem. The max volume on my Alpine deck is 35. when i turn the volume up to about 10, its listenable, when i turn it up to 15-18 its almost unbearably loud... In my other car this same alpine wouldnt get very loud until about 25... The xB is acting like it has amplifiers somewhere in the car. Now, since i thought that might be the case, I installed a Scosche FAI-3 for line level adjustments between my wiring harness and my Alpine deck, but then the sound was WAY too quiet and when i turned it up loud it became garbled and distorted...
The reason i need to get this sorted out, is because the subwoofer volume that comes out of the RCA's on the back of my deck is still controlled by my main volume ****, and if LOUD is only 15 which is not even half of my full volume, its going to be impossible to ever get any sound out of my subs...
PLEASE HELP
PLEASE HELP
Depening on which model alpine you have, you can control the sub output.
I have the 9831 and it lets you control the Sub Output. Also try playing with the EQ levels, different levels let you go up and down on volume.
I think it might have just been crappy speakers in the previous car or some power related issued. I had an alpine deck in a sunfire and I couldn't go any louder than 15/35 either. I mainly kept it at 11-13.
Get ride of the Scosche FAI-3 and check your wiring throughly. Make sure you arnt mixing the grounds, etc. etc. Are you using a harness adapter or did you hard wire it? If you are using a harnes adapter, all the wire colors should match up perfect. If they match then make sure the harness is matching up with the factory wiring. Ive seen it many times where the pins in the aftermarket harness are crossed.
i bought my adapter from car domain, its the model that is recommended in the FAQ @ the top of this forum. I removed the FAI-3 from the system and wired it back up but im still having the same problem as before... it gets really loud @ 14-16 and thats not enough volume on the master dial to send any amount of signal to my sub amp in the trunk... ive checked and re-checked the wiring. when i originally tried using the FAI-3, in addition to running the deck through the FAI-3 i also ran the ground wire from the deck through the FAI-3 and then to the harness... could that have caused any problem?
the fai-3 will only limit the output coming out of your headunit. It is only designed to covert the hi level signal out of your high powered deck into low level signal that amplifed stock systems require.
remove it completely, there is no need for it.
What is your sound setting at? Does it still make the noise even if the loudness if off and all your setting are flat?
What head unit the that deck come out of?
I got everything sorted out. I took the FAI-3 out of the system, and use the gain on the sub amp and the "bass eq" in moderation on the sub amp to match the bass output to the mid/highs... btw its an alpine deck and an alpine sub amp. heres a link to pictures of the setup.
https://www.scionlife.com/forums/viewtopic.php?t=23024
CPL_Radar
03-05-2015 05:42 AM
cid_mcdp
01-05-2015 02:45 PM
crocker
12-02-2014 03:44 AM
TheRedBox
31
12-02-2003 04:53 PM
