VVT-Li Guage Cluster
HUH? there is an ECU controlled valve to feed oil to the cam timing adjusting gear to advance, retard and hold the timing.
https://www.scionlife.com/forums/viewtopic.php?t=30793
Right it doesn't kick in it just varies as needed so you could watch the control valve blink an LED as it advances and retards timing but there isn't any direct measurment that is available unless you can "talk" to the ECU with the new ScanGauge and get a reading off it that way.
Scion Dynasty
well, i guess it would be a shiftlight behind the gauge face
but its not gonna be a separate light, it'll be a color change from white to red once it reaches a point between 6k and 6,5k
sounds simple, but is probably gonna be difficult...
i suppose i'll contact LEDmod and see what they say
