Where does the Fog Lamp Relay go?
Okay so I tried to save myself a few bucks and order some parts off of eBay. I have the factory fog lamps from a Toyota dealer but I cannot figure out where the relay goes. I have looked at the fuse panel under the hood and under the dash. I see where you could put a relay but there are not metal tabs in the whole.
This is supposed to be a complete kit, brand new in the box and I believe it is. It does not come with instructions because a Toyota tech is supposed to be installing them, not a shade tree mechanic like myself. By the way everything else was very easy and I have it all installed, I just need to know where to put the relay so they will work.
___
___
check out this article
http://www.overboost.com/print.asp?id=1098
be warned though .. getting that socket loose isnt as easy as they make it sound .. i couldnt get mine loos when i was installing the fogs .. so i kinda reached around the back and plugged the relay in
I new it had to be easy. I just couldn't find it. For anyone else trying to do this, you do not have to remove the socket, you can reach around and install the relay with the wiring socket still installed. Also you do not have to remove the panels except for the fuse panel.
Thanks for the help, Guys! Either of you tried to install the Cup Holder Illumination Kit?
I guess I will try and tackle that in the morning.
__________________
__________________
and i am not sure why they say to remove the kickplate panels lol... no need for that
Im glad you got em installed
HAHAHA... oh man.. i hated trying to get that socket out too so I think that step in the instructions is USELESS, to pry it off.
SUre it's for convienince but, all you had to do was feel the socket and stick in the relay.. I could have saved myself 1hr hahaahahahah.
Anyway, I hope installation for my randodes goes easy! Getting them soon!
Yes, this thread just saved me an hour of my time and avoided the risk of breaking all that plastic stuff. Gotta love ScionLife!
Thanks guys! RPM
PS/BTW: Although it's pretty obvious if you study the other relays, here is the spade pattern for popping the relay into the socket.
Top
Bottom
Thanks guys! RPM
Top
Bottom
it is a lot easier to talk to real people than it is to talk to engineers and techs. Real people figure out the short cuts. I just finished the cup holder illumination. It was pretty easy too. I think I may have spent one hour at the most.
By the way has any one attempted to add the cruise control themselves. That is my next project.
Originally Posted by KevinxB
I didn't have as much trouble getting that socket off fuse the block as I did getting it back on. Have fun...
