xB Speedo Problem
ok, if you've taken the speedo needle off (and my understanding of the bbist is that you DO NOT need to take the needle off with the bbist), it may be inaccurate.
you can recalibrate the needle by rotating it manually counterclockwise.
Re: spedo
Originally Posted by thekook
try this. take the needle off replace it with the needle pointing at the fastest speed then slowly go backwards till it reaches zero. this should help. It did for me.
If the needle hasn't been removed, you must have accidentally bumped it off of zero. To fix it you may have to take off the fuel and tach needles because the speed needle is long enough to swing down and hit them and you don't want broken needles.
Go here http://www.forcespeed.com/XBInstall/XBInstall.htm and follow the instructions near the bottom of the page to get your needles back where they need to be.
RY_TC07
07-18-2017 05:18 PM
AKgoalie7
11-25-2003 01:11 AM
bBted
9
10-04-2003 11:15 PM
