For you DIY heres some wiring info
12volts wht/blue (40A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock blue/white - driver kick, 14 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow/black (double pulse) - driver kick, 14 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/orange 5wi driver kick, 9 pin plug
Unlock Motor yellow/green 5wi driver kick, 9 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/white - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release brown/yellow - driver kick, harness to rear
Notes: Meter this wire while opening the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/yellow (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/red + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white/red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Parking Lights- N/A
Headlight black/white - headlight switch
Speed Sense purple/white radio harness
Wipers gray (L), black/red (H) + windshield wiper switch
LF Window up/dn red/blue - green/white A driver window switch in door
RF Window up/dn red/blue - green/white A driver kick, 9 pin plug
LR Window up/dn red/yellow - green/yellow A driver kick, 4 pin plug
RR Window up/dn red/black - green/black A driver kick, 4 pin plug
Sun Roof open/close N/A
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12v blue/yellow + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black/red + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- lt. green - blue +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
Second Starter N/A
Third Ignition N/A
Parking Lights- N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Notes:
Parking Lights- N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
do ya think you can help me install this???i found a power and ground ,and each blinker but do i need to plug it into both ??please help??or if ya can give a diff way?
http://www.racinglab.com/noquflco.html
That is a pretty poorly written how to install guide on their website. First off, DO NOT use a test light in your car. They tell you to. don't. period. I do not know if this will work in our cars. Or any car for that matter. You would need a left and right blinker wire to hook up. I just do not see how this would work. It appears they are suggesting that all lights, parking, blinkers and running lights get hooked up to 1 wire. that is a no-no. Cool idea, poorly planned out.
Of course, I may be not seeing something important.
i have that same model and it was on my 1990 integra the diff from the xb and integra is the plug ...on the integra it was a relay that you can unplug and it was only 3 prongs and on the xb it has 13 slots..on the integra i hooked up to 2 plugs and one to the frame for a ground..
This is great iinfo. Did you know that the entire 06 xB wiring diagram is available here? In PDF format. No more guessing ...
Hereyago:
https://www.scionlife.com/forums/viewtopic.php?t=138456
Hereyago:
Did you actually look at it? I took a quick peek at them (as I already have the real Toyota printed Wiring Diagrams) and it looks identical. I'm almost positive that it mentions colors of all the wires. And it describes exact locations of all the harnesses and connectors.
I'm not sure if I understand you guys. The pdf files have the wiring diagrams in full color. I just looked at the "052-053 charging.pdf" file (for 06 xB) and all the wires are shown in their actual colors. Those pdf files are an exact copy of my very readable (and color) Wiring Diagram Manual from Toyota. Maybe I just don't get it....
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
MadSciontist_xB
05-10-2015 06:28 PM
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
