#1 Number one Sleeve and Spring Coil-Overs
Old 03-29-2007 | 08:27 PM
JDMbB83's Avatar
You have to try out different things with these cars to really get to a decent level of performance.
If trial and error are called malboro burgers, I might refer to them as Heineken Shakes.
Old 06-21-2007 | 02:32 PM
proctorsilex's Avatar
anyone ever try these?
i am only interested in the perches for the front. at that price, the springs are probably crap and i would never run perches in the rear without adjustable length dampers.
Old 06-27-2007 | 05:58 PM
nerdsports's Avatar
Im only interested in the sleeve/perches for the rear. Apparently the D2 rear perch/sleeve are about 2.6-7" and I cant use an Eibach spring w/ a higher spring rate.
I'm looking for a regular coilover set to just use the rear perch/sleeve.
Old 06-27-2007 | 09:53 PM
nerdsports, i have the ksport coilovers which come from the same manufacturer. your rear dampers should allow you to shorten the length to hold in those linear springs. i never measured the rear perches for mine.
http://swiftsprings.com/products-racing_main.html sells 70mm springs that might work for you. double check the top perch.
Old 06-28-2007 | 12:39 PM
TheJonas53's Avatar
Anyone have pics with the sleeves in the front?
Old 06-29-2007 | 06:38 AM
SupaStarxAKid's Avatar
I'm sorry, but i'd never buy products from a company called #1 number one...lmao
XB06
15
10-01-2022 10:24 PM
heiko592
10-14-2020 02:48 PM
chenboly
05-29-2015 06:59 AM
ganyon
12
03-31-2015 03:58 AM
yamahamx117
Scion xD Suspension & Handling
12-25-2014 01:54 PM
Quick Reply: #1 Number one Sleeve and Spring Coil-Overs
