Aftermarket springs & shocks vs. Coilovers
I plan on lowering my xb, as soon as I get my rims, but want to know what is the best, hassle-free way to do it. I don't plan on racing, I'm more of a cruiser. I don't know whether to go with 2" aftermarket springs (probably goldlines) & Trd shocks/struts, spy's springs & shocks combo, or coilovers? Any info. or opinions would be much appreciated.
Coil springs and struts are the most cost effective means.
Coilover suspension like TEIN , Tanabe are a great set up so you can raise and lower the vehicle. Some include damping adjustability, pre- load and camber plates.
-------- Nice kit if plan on changing any of the above features for the track for example.
If you anticipate to just lower the car once and improve handling from stock.
I'd go with Spring set and TRD Struts.
Hope it helps!!!
Hope it helps!!!
if you can't afford a true coil-over kit you can always look at a sleeve kit which uses a stut and lets you adjust the ride height. if it is for cruising, springs will be the way to go.
I'm very familiar with the Sleeve kit. I don't recommend them in my opinion that's why I didn't mention it.
My experience has been less than favorable with the sleeve kit. Some rattle and make noise.
If youare really serious of getting the sleeve style kits. Please use uprated struts and use a quality kit like "Ground Control" Some owners of AE86 weld them on to the struts to keep them from moving.
Rule of thumb in the aftermarket parts business "You get what you pay for"
By no means I'm discouraging anybody... It's just been my experience with the Import scene of almost 12 years.
Hope it helps!
Hope it helps!
The best way to approach the lowering of your car is to determine how low you will ultimately want to go. If it's no more than 55mm down, then you can get away with just a set of aftermarket springs (the lowest most aftermarket springs for the bB and ist go is 55mm because that is the limit at which your stock shocks and struts stop working effectively) with the stock struts/shocks. Being that your stock struts/shocks will have such low mileage on them, they will last for a pretty long time, even with aftermarket springs. Of course, their lifespan will also be contingent on the sort of streets you drive on. Crazy bumpy roads with potholes and expansion joints galore will of course kill your shocks quicker. If you know that you will want to go lower than 55mm down, then your only true option is to go with coilovers or an air suspension setup. Disadvantage to taking this route: $$$
I want to lower my car now but need to lift it again in March for a trip to Mexico .I'll be driving on a few dirt roads and nasty speed bumps. I know coilovers are the way to go but I think that the price for them is still too high and will probably come down once more companies (like Ground Control) start selling them for the xb. I was thinking of just throwing on some Goldlines or Spys for now(what's better?) and putting the stock ones back on in March. Would my shocks still work well with the OG springs after a few months of driving with a 2" drop?
Hope it helps!
Hope it helps!
Does anyone know the reliability/longevity between aftermarket springs/shocks vs. coilovers? I'd want a setup that would last for a very long time, and hassle-free. Also, does the ride's smoothness/stiffness differ between the two setups?
The problem with lowering your car with springs and not switching out the struts is that your struts have a higher chance of going out. The struts are specifically made for a specific amount of travel. Decreasing that travel decreases the longevity of your struts. The true way to do it is to go get new struts for the drop you want to do, and get lowering springs. Don't get me wrong, I've heard of lowered cars with stock struts still going after 10 years. I think it may be kinda hit and miss. I've also heard of cars going for a year and having to buy new struts. As far as the longevity of springs vs coilovers, from what I gather it's pretty much the same. So long as you get decent brands of both you're pretty okay. The difference is really in price. For some TRUE coilovers you're looking at spending a good $500+ whereas with springs about $200. You're paying the extra money for the adjustability. I would also imagine that the ride quality is based on the spring or coilover. Lots of people running the spys say that the ride quality is improved. I'd definately do a search just to see peoples opinions of them. Anyway, that's just my two cents.
trd struts can be used with any springs. If you wann go real low, and you are just a "cruiser" i would recommend the air setup....as i'm sure eric would tell u, its just for cruzin tho, no fast cornering etc. but, if u still wanna go real lo and still race around and stuff, then get the coilovers or the springs
fluxingnation
12-26-2014 04:28 PM
scionaraxb
10-14-2003 03:20 PM
swtbabiboi4u
10-10-2003 01:40 AM
