Air Ride blah blah blah.........
Old 07-10-2008 | 06:19 PM
DarkSide_xB's Avatar
check out www.fbimini.com and contact Phil there.
Old 07-26-2008 | 03:25 AM
usdmbB's Avatar
Quick ? with your ES struts do you have positive or negitive camber when down?
I to have heared the popping noise. The XB I recently bought was already set up.
ES strus in front, so is positive camber normal. Any info would be great.
Old 07-26-2008 | 04:03 AM
TerribleTed's Avatar
Camber with the first design Easy Street struts is positive (even at a ride height of only minus 2" or so...not sure about at factory ride height tho) it should be slightly negative at ride height. Adjustment requires camber adjusting bolts or modification of the strut lower mounting holes etc to achieve proper camber.
I just received the second design Easy Street struts yesterday to replace my noisy, defective first design ones. The upper strut mount is totally different than before and appears to incoprorate a much beefier anti clunk/ratttle bushing. The bottom of the new struts has elongated upper bolt holes allowing adjustment of the camber without adjusting bolts. I will not have time to install the new struts till next weekend...am curious to see how they ride.
Old 07-26-2008 | 04:54 AM
usdmbB's Avatar
Thanks i really hate having positive camber
Old 07-28-2008 | 10:11 PM
hotboxn's Avatar
Team Echo
received my new setup from Jeremy after warranty exchange just last week. These new ones not only dont make the clunk, but they are sooooooo much smoother. I was so happy that these were under warranty. I recommend these to anyone out there looking at what front setup to go with. When I had the old ones, I wasnt so sure. Def props for the redesign.
Old 07-29-2008 | 04:00 AM
I really must find time to install my replacements. You have just given me a stronger urge
Old 07-31-2008 | 03:16 PM
ogerdgonz's Avatar
Glad you guys are enjoying them... I sent many emails and photos to Jeremy to get this redesign right.
Old 07-31-2008 | 10:47 PM
SuperMario6582's Avatar
as soon as i can get some extra cash, i was thinking of replacing my front setup with the new easy street ones.
Old 08-02-2008 | 02:44 PM
I installed my replacement struts last night, The mounting hardware is total BS garbage (should not use nuts and bolts (cheapy hardware also) to install the top of the struts, should be studs on the struts as per normal). The damper adjustments are poor as they were in the last version (9 position detents are not distinct...I am not sure that my left strut has more than 6 positions). They do no clunk, they certainly ride better, they do go higher. The new built in camber adjustment in the lower sturts is insufficient. Adjusting camber fully negative at my ride height still results in an out of spec positive adjustment (at factory ride height they may be ok, but at a 2.5-3" drop they do not allow enough adjustment), have camber adjusting bolts available.
Personally I would not mind paying a little bit more cash for a truely high quality part. I guess either I am in the minority or many manufacturers simply do not care about providing a truely excellent part:/ My 2 cents.
Old 08-04-2008 | 03:50 AM
Spider13's Avatar
And here I thought airlift had turned over a new leaf.
Old 08-05-2008 | 02:14 AM
Yeah. The struts seem to work well. The ride is excellent. Better than factory IMO (factory was a bit stiff and jouncy to me). It is too bad they did not go the extra 5% to include at least some decent fastners.
Old 08-06-2008 | 08:36 PM
jx1379's Avatar
terrible_ted - talk to jeremy at airlift. i actually drove up to michigan so they could take a look at their new design on my box and fix what problems i encountered! they also took care of me in 2 days and the new "new struts" should be heading out the door shortly!
Old 08-07-2008 | 11:48 AM
Gothbox's Avatar
wellI am going to be pulling mine off this weekend prob, to send back to get the new ones under warranty(thanx Spider13).
so when I get my new ones, I will be sure to update. I have heard and seen that they do go up higher(don't care really), but they also don't go as low as the old ones. that the old ones, would sit the axles on the frame, but the new ones don't. so I will have to wait and see how that works out.
Old 08-07-2008 | 11:56 AM
Gothbox's Avatar
here is the diff, (pic from the "other" site)
old struts,
new struts
Old 08-07-2008 | 09:14 PM
MuNkY's Avatar
Scion Apocalypse
I had talked to them about this issue, and they ASSURED me that the camber issue would be taken care of by the elongated hole. ugh. I told jeremy on the phone that even with ksport camber plates, they were adjusted in as far as they would go, and the alignment tech said they still were a bit off. I am with you man.. the clunking is what really annoyed me.. but i just cant live with the positive camber.
sigh..
Old 08-07-2008 | 09:32 PM
jx1379's Avatar
gothbox - whaddya mean the "other site"? i share equal amount of love on both but i cant figure out nor had the time to put pics on scionlife (its was easier for me at the time to put pics on clubxb)....but j/k nonetheless.
munky - heres what i know: the newest struts were designed with a larger bag and the camber brackets on the bottom were to long/far out for me to fit a 18x7.5 38 offset on toyo tires. i was rubbin bag so what they did is make a shorter/skinnier camber bracket which that gave me a little bit more room, but the only solution they found was to put on a smaller diameter bag (something like .25 - .5") on and everything fit like a glove. no more rubbing and the front feels so much more solid than on the 1st gen struts. not to mention the new strut mount works wonders and no more clunking.....i just cant go as low as on the 1st gen struts (see pics above). hope this helped
Old 08-07-2008 | 11:47 PM
sigh..
I got camber to -1/2 a degree. We used the Airlift struts as supplied and also used a camber adjusting bolt in each lower mount hole. It would not give us any more negative than that without further modification. I may radius the mount holes a bit to get a bit more close to spec a my ride height.
Old 08-08-2008 | 03:56 AM
Gothbox's Avatar
ha ha its cool, I just had been warned on here in the past for "promoting" other scion sites, so I did not want to drop names, thats all.
Old 08-08-2008 | 03:46 PM
jx1379's Avatar
really....but good to know!
Old 08-09-2008 | 01:59 AM
Gothbox's Avatar
yea I thought it was a bit much as well. but oh well.
so yea, I will be sending mine off this weekend, can't wait to see how they do.
Quick Reply: Air Ride blah blah blah.........
