Any tricks to make my back end drop a little lower
Old 05-07-2008, 08:40 PM
Nastos's Avatar
Default Any tricks to make my back end drop a little lower
i have skunk2 springs and im not really happy with the drop in the back any ideas on making it a bit lower? the front looks good but the back could use another inch
Nastos is offline
Old 05-07-2008, 08:49 PM
Thumps's Avatar
5 or 6 50lb bags of concrete mix in the cargo area.
Might have a slight effect on acceleration and braking performance though.
Thumps is offline
Old 05-07-2008, 08:51 PM
Nastos's Avatar
lol
Nastos is offline
Old 05-07-2008, 10:37 PM
sizzlinscion's Avatar
get new springs
sizzlinscion is offline
Old 05-07-2008, 10:49 PM
CDogbert's Avatar
However, you'll be prepared if you're ever stranded in the woods and need a hard surface for things like playing a rousing game of four square or hopskotch.
CDogbert is offline
Old 05-08-2008, 01:52 AM
Sciond's Avatar
use the echo rear shocks....and use Monroe's
Sciond is offline
Old 05-08-2008, 01:59 AM
Nastos's Avatar
whats monroes? struts?
Nastos is offline
Old 05-08-2008, 02:21 AM
Sciond's Avatar
Monroe Sensatrac rear shocxs
Sciond is offline
Old 05-08-2008, 04:46 AM
burstaneurysm's Avatar
The rear shocks have no effect on the rear ride height, only the front.
burstaneurysm is offline
Old 05-08-2008, 05:23 AM
Nastos's Avatar
yeah if i was gonna throw down all that money id just get some s techs... i didnt know if there were some minor suspension mods i could do to the stockies to make em a lil lower... probably just see if some one who is too low wants to trade springs
Nastos is offline
Old 05-08-2008, 08:54 AM
Music City Scions
bB2NER's Avatar
Only way to lower your current springs would be to add some spring clamps. Not sure if you'd have enough space between the coils tho to fit them in tho. You would basically clamp 2 of the coils tight together lowering the ride height more.
bB2NER is offline
Old 05-08-2008, 01:53 PM
Boxer_Rebellion's Avatar
Actually that is incorrect. Check the Sensatrac threads on this. The difference in gas pressure in the stock shocks actually raise the height up about 1/4" over the monroe's design. There have been before and after shots to illustrate the difference, and I saw this on my own car.
Boxer_Rebellion is offline
Old 05-08-2008, 02:13 PM
Nastos's Avatar
but how would that change the weight of the car resting on the springs... i have heard alot that shock swap wont change ride height bc its all in the springs
Nastos is offline
Old 05-08-2008, 02:32 PM
Hmm... I was having an issue the other day and swapped my Monroes with OEMs... the ride height didn't change at all.
In fact, I even lowered it just on the spring and even that was only slightly lower.
Old 05-08-2008, 02:33 PM
Plus, if he's looking for an extra inch in back, it might be worth it to just get new springs - like the DF210s.
Or toss a heavy sub box in the hatch.
Old 05-08-2008, 02:40 PM
CarbonXe's Avatar
Move the battery to the back .
CarbonXe is offline
Old 05-08-2008, 06:56 PM
Nastos's Avatar
lol i was thinking about getting an extremely heavy system
Nastos is offline
Old 05-08-2008, 08:03 PM
CarbonXe's Avatar
150-200 lbs added to the back should be enough for a 4-6mm drop.
CarbonXe is offline
Old 05-08-2008, 08:12 PM
Nastos's Avatar
so roughly one dead body?
Nastos is offline
Old 05-08-2008, 08:14 PM
CarbonXe's Avatar
If you feel like putting up with the smell, sure.
CarbonXe is offline
Quick Reply: Any tricks to make my back end drop a little lower
