best sway bars for the money?
i had progress and whiteline...
progress was good for daily driving. i really liked how the feel of driving changed when i added it on.
then i got whiteline. huge difference, much stiffer in the rear. loved the whiteline. best sway bar for the xb in my opinion.
white line
When I searched for sway bars whiteline never came up? What's the diffrences between progress and whiteline? Size? Stiffness? Everytime I get something someone on here mentions something better. Just sold my hotchkis now I am hearing their is a better sway out their. Let me know the whiteline perks. Thanks by the way for replying to my post.
i remember early on everyon was trying to progress was better than whitleline. they've got years of experiance making swaybars. reason why they do so well what you'll need is a part # though to find it. i do belive its still a 22mm bar though.
So tell me what you like.
What's your take on why you sway towards whiteline? The bars are the same thickness so is it the design? Gotta ask because if its possible I am trying to put the best on and keep it that way. Heard a lot of people talking about progress and how hotchkiss is flimsy. So I sold my hotchkis 2 days after receiving it in the mail. And ordered a progress which hasn't arived yet and now a new bar that I hadn't heard of pops up. Soooo want to know all the good points of your bar. Also what are you running on the front? Sway or strut tower. I started a thread on this topic but no one will respond. Thanks again.
hawaii, thanks for that link that was a bomb thread. by chance do you know were to find a thread on if i should run a strut tower in the front with my progress in the rear? will it help ? or hinder my performance.
Re: best sway bars for the money?
Hotchkis? Progress? Any one have any experiences with another sway bar set up
They would be willing to share
I have the DC Sports strut tower bar, Progress rear sway, and I'm lowered 2" with the Eibach sportline springs. I'm also riding on 18 x 7.5 wheels. Considering that, my first-hand experience with the strut tower and rear sway combo is that handling is much improved and more responsive. Alot of that is also attributed to the lowered stance, but the overall feel of the car in "spirited cornering" is solid. Much, much less body roll and more stability. Agree with most folks that the Progress sway is good for daily drivers and the recreational racer. Hope this helps with your decision-making regarding suspension set-up.
i hate to interject but i have to make this clear
body roll has nothing to do with handling
"sway-bars" are kinda like Band-aids for improper spring rates
if your spring rates are correct, the amount of stroke will not be reduced and the vehicle will handle better
sway bars only connect the opposite wheels together
so you are limiting stroke with the idea that a visually "flatter" car while cornering is ideal...it isn't
most autoX racers disconnect their sway bars totally
get good coilovers or spring/shocks and you will get everything you want
ya just have to thin of the stroke (and try not too kill it)
thanks....sorry
thanks....sorry
thanks....sorry
thanks....sorry
Would you tell me that sudden weight transfer at the top of the car does not hurt handling? Your CG is in a rising motion...this can not be beneficial.
The statement "most" auto-x racers disconnect their swaybars is a misleading statement. Where did you get that stat? Most auto-x racers I've raced with have fully adjustable swaybars. Perhaps most you've raced with do not. I would refrain from generalities on this topic, though, as it seems difficult to get an accurate poll of who does and doesn't run a swaybar in auto-x.
Street performance and "feel" is normally greatly enhanced by aftermarket sway bars, regardless of spring rates. This thread is about a street driven vehicle, from what I can tell. In the real-world, sways are almost always definitely beneficial.
valid stuff
i was focusing on lightweight FF vehicles (EF EG Civics, etc..)
a ceartain amount of roll is necessary for weight transfer
most sway bars coupled with aftermarket stiffer springs leads to to much stroke limitation (gotta have stroke)
and can lead to traction loss or wheel lift-off
ideally, correct spring rates will not need a sway bar
i personally hate the way they feel on SOME cars, other cars it has improved the cornering slightly....with the negative of wheels coming off the ground in hard cornering
weight transfer makes/breaks traction
the load on the tires can be maximized only with enough weight on them
just my 2centavos, thanks
Agreed. Thanks for the clarification, TXbox. I think between our 3 posts we got the issue squared. Just didn't want anyone that's new to the hobby getting the idea of taking their sways off for normal driving. Otherwise, good input for all-out race machines. Later...
Bmfxtreme
08-18-2015 01:25 AM
