Camber Shims and alignment
Im guessing you installed the camber shims to make the car look cool. Well thats the trade off. To get the alignment back to spec you would obviously have to go back to stock (ie: remove the shims).
do your camber shims have the "Toe correction"?
what brand do you have? The "alighment should be on unless the front is out, but obviously the "Camber" is going to be way off in the rear because of the shims.. There is no alighment adjustment in the rears at all. could it be that the guy at the alighment shop said your alighment was off because the camber was out of spec, or does the box pull?
lots of things we do to our cars are trade off's... throw some nice big wheels on there and your spedo will be off... lower the box and your alighment may be out of spec... go turbo and your air fuel mixture will be out of whak (unless you use fuel management)...as stated there is always a trade off...
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
gedster314
Regional - Pacific South
02-19-2021 07:51 PM
Darrenohooligan
09-26-2015 07:21 AM
