Cusco Vacanza Zero-Wagon coils
k, we go to install it last night...the ride is much better than the Goldline springs/stock shock combo...i did the rear set up like how yours was Erick, having the perch at the bottom of the spring
i need to adjust the fronts more, i think i have the rears set at 23" and the fronts at 24" LOL
also, i am hearing a lil bit of clunking in the front, just as NCP31 described back in a thread in scionlife...he said it was to be expected with the pillowball uppermounts/camber plates
what i'm trying to figure out now is a little "clunk" sound i'm hearing from the rear when i'm pulling into my driveway (angled/slow) or any other sloped areas (gas station etc.)...everything seems to be bolted right though, we're going to check it out again tonight..
JC
JC
The clunking sound is probably the metal spring rubbing on it's coils or on the rear perch. Should settle down in 1-2 weeks. If it still persists, you can get some rubber spring wrap to quiet it down.
~ M-flo
~ M-flo
k the "clunk" sound when i pull in my driveway or sloped areas seemed to have disappeared after some driving around...i guess everything just had to settle in...i still have to adjust the fronts, then i'll take some profile shots :D
JC
JC
