DIY Rear Helper Bags
I am not responsible if you break something, hurt yourself, or just do something stupid.
Tools needed:
Jack
Jack stands
17mm wrench
Air Lift 1000 Load Level Air Springs/Bags
Lift car and place a jack stand and repeat on other side.:
With 17mm wrench remove shock and remove spring:
Open Box:
Compress bag and install in spring:
Install supplied air line:
Install puck:
Install spring and shock with air line coming out of the bottom of the perch. (per air lift instructions):
Run your air lines:
Run your air line hide or mount valve where you would like. Cubby behind the tail lights work well.
With air:
9.5"
No air:
5.75"
Tools needed:
Jack
Jack stands
17mm wrench
Open Box:
Install puck:
Run your air lines:
With air:
9.5"
No air:
5.75"
First off: Nice box. Love it much.
Second: Nice DIY
Third: How much $$$ was the set up?
Fourth: How long does it take to inflate and deflate?
Fifth: Can they inflate on the go or do I have to do it all at home?
Second: Nice DIY
carid
01-22-2015 12:49 PM
