View Poll Results: can you really be too low?
prefer stock ride height
0%
medium height
39.47%
the lower the better
60.53%
Voters: 38. You may not vote on this poll
dropped on its NUTS!
Old 03-31-2004 | 07:26 AM
ftaxi138's Avatar
Default dropped on its NUTS!
i wanna go as low as i can. how low can i go, how much travel do the stock struts have and what kind of springs can get me real low?
Old 03-31-2004 | 07:58 AM
unlmtdndeavor's Avatar
if u want to go real low, go with air suspension. if u want to use springs, go with a true coilover, cusco goes close to a 4" drop i believe
Old 03-31-2004 | 09:44 AM
Djuan's Avatar
Default medium for me
I'd like the medium height, since I got this jacked up steep driveway...
Old 03-31-2004 | 10:25 AM
scionxb04's Avatar
pot holes and driveways are your friend when your dropped....
Old 03-31-2004 | 07:08 PM
jonbee's Avatar
low as possible!
Old 03-31-2004 | 07:28 PM
ftaxi138's Avatar
i'd rather stay away from air, but i'll check into cusco thanks!
Old 04-07-2004 | 07:46 PM
eric_m's Avatar
ok there is a problem. i tried cutting the stock springs, and got the car super low. like 4.5" lower than stock. it looked awesome but turned out to be a nightmare because the front lip scraped on everything. there is just a limit to how low you can go before the lip becomes a burden. unless you don't care about the lip. technically you can buy a new front lip every year or so and just dump it as low as you want, but without air, there is only so far you can go.
here is my car with 16" rota grid:
and with 19" axis mesh 2s:
also keep in mind that you can lower the car more with bigger wheels, since they raise the car off the ground more. when i got my 16s, i got really low profile tires, so i could go as low as possible. the car is about 3" off the ground in those pictures with the 16s and is still not low enough for me. but i've got some things i'm working on now and hopefully soon i will get as low as i originally wanted to.
Old 04-08-2004 | 08:58 AM
squirrel's Avatar
I think Ken (NCP31) is down around 3 1/2 inches w/ the Cusco coilovers installed.
Check my Palo Alto pics link for pics.
Old 04-08-2004 | 09:01 AM
bBted's Avatar
i think 2.5 would be a perfect drop
Old 04-09-2004 | 06:37 AM
ftaxi138's Avatar
Eric M. your scion looks bad ___ man its definatly on the ground. It looks sick like that. hows the ride though is it real bad and stiff?
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
rvascion
11-12-2020 03:23 AM
Sgtfluffy16
09-30-2015 01:42 PM
ScionLife Editor
09-24-2015 10:50 PM
antayala
09-04-2015 05:12 PM
Quick Reply: dropped on its NUTS!
